0 Members and 1 Guest are viewing this topic. Read 10126 times.
If I read the documentation on the latest firmware update from OPPO DSD is now converted to 24/192 internally to preserve the functionality of the remote volume control as DSD cannot be manipulated in the DAC to facilitate volume changes. When switching from PCM to DSD or at the start of DSD file playback, the analogue output defaults automatically to 100%. Also if I do a firmware update I will do so by requesting a disc be sent with the firmware on it, apparently if an update via download is corrupted or interrupted the player can be "bricked".Scotty
https://www.oppodigital.com/blu-ray-bdp-103/blu-ray-BDP-10x-Firmware.aspxThis is from firmware Main Version BDP10X-75-0515.Release Date: May 19, 2014 Applies to Loader Version:6U1000 or 7B1300 (BDP-103),7B1300 (BDP-105, BDP-105D, BDP-103D)Sub Version:MCU103-05-0916 (BDP-103),MCU105-04-1113 (BDP-105),MCU13D-01-0618 (BDP-103D),MCU15D-01-0930 (BDP-105D),DB10X 131030 (BDP-103D, 105D)Added a safety feature for BDP-103/103D: the "SACD Output" format is set to "PCM" by default. The reason is that the digital-to-analog converter (DAC) used on these two models cannot adjust the volume for DSD signals, so the analog volume level could automatically switch back to 100 when a DSD stream is detected. This safety feature will force the DSD stream to be decoded as a PCM stream before sending it to the DAC, which can help control the volume when loading SACD disc(s).To put not to fine a point on it, dude we're screwedScotty
You might look at a used 95. Some think it's better at music than the 105, and by being a previous model, much cheaper.
Keep in mind current models are the 103, the 103D and the 105D - https://www.oppodigital.com/products.asp?cat=16Price wise for the above models, one is talking $500, $600 and $1,300 respectively.The 103D and 105D have the same video.
Thanks a bunch for the replies. My concern is that for the 800.00 difference between the 2 am I better off with an 800.00 DAC and the 103 over the 105. The video is not that important to me and if I understand correctly I would have more options with a stand alone DAC.
