0 Members and 1 Guest are viewing this topic. Read 6827 times.
No there is no difference. There is no "audio" being transfered by ethernet. At that stage it is still just packets of data that are later reconstructed into a file in SBT memory. With ethernet (wired or wireless,) data packets can even arrive in the wrong order and they are still reassembled correctly by higher layers of the network protocol. As long as the reconstruction is completed in time there is no difference in SQ. The only SQ symptom of ethernet problem that you would hear is stopping of play for a short or long period. The tone quality or other audiophile terms wouldn't apply to ethernet issues. SB3 and Duet had about 30 seconds of buffer memory from when network disconnected to when the music stops, so there is little chance of any impact if you have a good connection, whether it is wire or "wife." Once the assembled file is streamed from memory then the sample timing jitter and analog stage SQ issues become factors.
Ps - don't think Ethernet to wifi extender is going to sound better than wifi in SBT - you'd have to do Ethernet direct to router. If anything with the extender all else being equal it might be worse (introducing another device and more data processing than necessary). Ethernet cable quality affecting SQ is debatable - Even believers have informed me that the noticeable improvement is subtle vs upgrades of other similar cost. I think the improvement would even be more marginal into a wifi extended. A good and real CAT 7 cable should be sufficient with its superior shielding. Beware that there are true and fake CAT 7.
A wifi bridge worked very well for me and sounded better. It was combined with turning off the wireless on the SBT. I seem to recall some computer literate person telling me that, in fact, those little smart packets would move around less since the laptop would talk directly to the SBT via the ethernet cable. The only downside is that you really need to keep your laptop in your listening room as a permanent device.Also, as noted, the bridge is much more stable than wifi. I know a lot more about wifi now, such as assigning static addresses to devices, but when I was a wifi newbie my SBT caused many a day tearing my hair out to figure out why it worked some days and then just decided not to work anymore. And 24/94 was basically impossible in my house using wifi.
