300B Question
0 Members and 1 Guest are viewing this topic. Read 971 times.
Escott1377
300B Question
« on: 11 Dec 2015, 01:06 pm »
Hopefully you guys will help w/ this - I know you are typically geared more towards DIY and there is some content here.
So, I bought this pre amp and assembled...
http://www.transcendentsound.com/Masterpiece.html
The stock 300B's are white base EH's, which is about as bottom of the barrel as you can get.
I talked to a KR Audio dealer me that their quality has really gone down hill and recommended Emission Labs product.
I looked thru their offerings and their 300B Mesh gets really god reviews, but it operates at about 70% of a standard 300B tube.
http://www.emissionlabs.com/datasheets/EML300B-mesh.htm
With this being a pre amp design, I would essentially be limiting the load that the pre amp can drive w/ using the mesh option?
I'm not sure and like I said, you guys are spot on when I have asked for advice.
Thanks -
