Other Stuff
Archived Manufacturer Circles
GIK Acoustics
Before and after measurements
0 Members and 1 Guest are viewing this topic. Read 1997 times.
cherrell
10 Dec 2015, 03:01 pm »
I have recently installed 8 Soffit traps in the front 4 corners of my listening room. 4 of them have limiters, the others are just the normal broadband type. They have cleaned up the sound of my system immensely. Here are some measurements I took. The Red traces/graphs are with the treatments. The green is with out. More work is to be done though. This is just a start.
Here are the measurement:
http://imgur.com/a/dQy2I
Glenn Kuras
Industry Participant
Re: Before and after measurements
14 Dec 2015, 05:51 pm »
Wow that is a big change!! When you have a moment can you send me the REW file? I would like to open it up in my REW program.
Other Stuff
GIK Acoustics
