0 Members and 1 Guest are viewing this topic. Read 13878 times.
Well, chokes don't regulate....they filter.
Oops bad choice of wording thanyou for the correction without insult. Much appreciated.charles
In this particular case I think we can assume the current draw from the preamp will be near constant. (It would be very easy to measure to confirm that.)"Regulation" generally refers to some sort of active regulation that holds output voltage constant with varying voltage input and/or varying current output requirements.I imagine the Dodd battery preamp has no PS regulation at all in its stock form.....but somebody can correct me if I'm wrong on that.Dave.
voltage regulation is provided by the battery constant voltage...
Artifacts sounds good, so why not. Yes, artifacts it is. If I defined "properly" I would have to reveal/teach electronic engineering principles and designing. I do not give away design principles cheap.If you don't understand my description of the 11A in my previous post, it adds nothing nor subtracts nothing via years of listening testing, it does not alter the sonic/musical information. Dynamics, clarity, imaging, detail, depth, width, does not change. It reveals all the natural music that is recorded. It took decades and a lot of research/development/listening testing, and lots of money. You are more than welcome to come by for an audition. The main points I meant to address are presented in my previous post.CheersSteve
it's because of small batteries,Gary's preamp uses big ones...
Where are you located? The alternative is I improve your unit, see what you think.
Only one way to find out
I've actually seen a few designs that use batteries as the power source but still employ active regulation downstream.
We all know that is not true by definition. Of course if one can dice the 11A, then one can claim batteries are superior. However, since the 11A is perfect/natural, then there is no better, by definition. But just as important, no distortion from the power supply and no need for batteries. CheersSteve
Considering the many opinions here on AudioCircle as a start, the challenges continuously debated in objectively measuring everything having to do with an admittedly not completely understood science of sound reproduction and the resulting human interaction with it, and the completely subjective positions of people filling in the missing pieces as best they can, saying any audio device (or anything created by human hand for that matter) is "perfect" is a stretch to put it politely and casting a hard line in the sand suggesting otherwise probably isn't going to go very far in backing that claim.
Respectfully, reading the references you provided, I would not argue that the 11A may be very, very good. I don't know first hand, as I have not heard one, but it is regarded in very good company. Considering the many opinions here on AudioCircle as a start, the challenges continuously debated in objectively measuring everything having to do with an admittedly not completely understood science of sound reproduction and the resulting human interaction with it, and the completely subjective positions of people filling in the missing pieces as best they can, saying any audio device (or anything created by human hand for that matter) is "perfect" is a stretch to put it politely and casting a hard line in the sand suggesting otherwise probably isn't going to go very far in backing that claim.
Davey, first do you have any idea what the ampere requirement is on the unit? That's important.
