0 Members and 1 Guest are viewing this topic. Read 13830 times.
...Of course, then there are the supercapacitors as used by Vinnie.... I have not looked into building a PS with them yet....
Charles,Since this is the lab circle I have to emphasize what some have already mentioned, that the quality and implementation of the DC supply matters a lot. The typical off the shelf 3 terminal chip regulator (LM12xx, LM317, etc) implementations just aren't going to get it done. As Danny said, the necessary level of elegance for a proper LPS can get expensive.I'm not recommending this guy's stuff at all as I haven't tried them, but the articles provide interesting perspective for sonicshttp://www.coreaudiotechnology.com/batteries-vs-linear-power-supply/http://www.coreaudiotechnology.com/faqs-about-our-power-supplies/I've used the KECES DC-115 power supply (since superceded to DC-116) with success for various low voltage applications like the Squeezebox and a Linux server, and have been quite happy with it at modest cost.http://www.keces.com.tw/5_english/index_5_english.htm
Thans Tom. Yes no off the shelf unit for me it will be a choke regulated power supply made correctly. Money is not an issue quality is. Thanks again for taking time to help.
Well, chokes don't regulate....they filter.I imagine you're talking about a variation of the DIY config that John Swenson offered up a few years ago? There was nothing fancy about that one, but it should probably yield good results in this application.Dave.
Yes something like the Uptone JS-2 would be nicehttp://uptoneaudio.com/products/js-2-linear-power-supply
That has promise. Thanks again.charles
The premise that we ALL need some sort of AC-power conditioning and/or fancy power cords and/or other gadgets is incorrect.
Grid, feeders, pole transformers, panel, house wiring, contamination from outside sources, DUT power supply design, etc, etc, are all variables.
IMO, given the same budget and taking a few sets of replacement batteries into account, an AC power supply would end being cheaper in the long run and differences in SQ wouldn't be much of a factor if both were designed competently.
Hey, if power cables from Home Depot are all that you need more power to you. But at the level I play that just doesn't work.
That's the best you have? Maybe one of these decades my system will be able to achieve the same orbit your system plays at. I will keep striving. Dave.
Dave,dont push it man,Danny has been polite with you,ps's also cause severe distortion whereas batteries are immune to it...
Little does Danny know that I actually have my Home Depot amplifier in service now too. It has a 240 input and functions as a welder also! And and it has auxiliary 120VAC outlets (with internal power conditioning) to run my circular saw and router. It's the coolest.Dave.
Steve I think you mean artifacts. And please define properly. This is audiophile stuff we're talking about. If it works you can purchase it at Best Buy, if it excels you might find it on here.
