New and need some advice
0 Members and 1 Guest are viewing this topic. Read 971 times.
stalbrecht
« on: 7 Dec 2015, 11:40 pm »
Hi, I am new here and back into audio.  I moved into a condo awhile back and sold all my higher end stuff and bought a Denon AV received with KEF surrounds and that was my system.  I did keep my Legacy Classic speakers in hopes of one day rekindling my obsession.
So here I am starting again.
I have been doing somer research and have always been interested in the Acurus and Aragon stuff.  I am thinking about a used DIA 100 mk2 integrated amp in the $350 range.  Then I started looking at a RL 10 preamp with an A150 or A250 amp that I would have reworked with Ken Ealey.  That looks like it will cost me around $1400.  Then I thought I am going to need a DAC anyways, so why not look at the NAD C375 BEE with optional DAC.  Used I can find this around $900.  There is my dilemma.  I'll be honest, the $1400 is a bit more than I want to spend right now, but I can do that in stages, buying the preamp and amp before mods is around $550-$650 which is more reasonable.
Any help would be greatly appreciated.
Re: New and need some advice
« Reply #1 on: 7 Dec 2015, 11:46 pm »
Welcome Stalbrecht  :thumb:
Today 2015 I would buy a EL34 SE (7W) or a Class D amp(mono).
If your speaker are 8 ohms 98dB(or more) single fullrange driver
7W is suited and a small Class D 100W is a powerful giant.
Guy 13
« Reply #2 on: 7 Dec 2015, 11:47 pm »
A warm welcome to AudioCircle Mr. Stalbrecht
Guy 13
« Reply #3 on: 8 Dec 2015, 12:43 am »
Greetings & Welcome to AC stalbrecht  :thumb:
stalbrecht
« Reply #4 on: 8 Dec 2015, 01:39 am »
Here are the specs for the Legacy Classics
Sensitivity: 92 dB @ 2.83 V/1m.
Frequency response: 22 Hz - 30 kHz +/- 2 dB.
Crossover frequency (Hz): 120, 2.8k, 10k.
Recommended Amplification: 25 - 300 watts/channel.
Impedance: 4 ohms.
Phil A
« Reply #5 on: 8 Dec 2015, 02:31 am »
Welcome to AC!
Phil A
« Reply #6 on: 8 Dec 2015, 02:52 am »
The NAD might not be a bad solution reading this review - http://nadelectronics.com/articles/Stereophile-Reviews-C375BEE-C565BEE
There's also accessories4less.com with authorized factory refurbs - http://www.accessories4less.com/make-a-store/category/integratedamp/home-audio/receivers-amps/integrated-amps/1.html
