SOLD: Behringer DCX 2496 with Pilgham Audio Mods
0 Members and 1 Guest are viewing this topic. Read 1994 times.
dpd
« on: 4 Dec 2015, 12:44 am »
Bump - a very good piece for WAY less than the HAL or DEQX systems
Great for use with bi/tri-amping your system.  Improved flexibility over the stock DCX 2496 with improved sonics.  Very light use.
$1,000 or offer considered.  Ships from 46835.
Behringer DCX2496 with a full set of mods from Pilgham Audio: Sample Rate Converter, Active Upgrade with 6 Channel Volume Control, Linear Power Supply, Regulators. Unit can be programmed from a PC (includes RS-232 to USB converter).  Does not come with a remote control (needs a simple Philips RC - info provided in the documentation set.)
The cost of the parts alone, including the cost of the stock DCX2496 is over $1,000.  Stock unit was upgraded from new.
Full set of documentation, including some schematics.  Additional pictures available on request.
For more info, see below
www.pilghamaudio.com/diy/diy-support/dcx-active-upg
www.pilghamaudio.com/diy/diy-support/dcx-src-clock
www.pilghamaudio.com/diy/diy-support/dcx-vreg-5v
www.pilghamaudio.com/diy/diy-support/dcx-pwr-supply
« Last Edit: 7 Jan 2016, 02:41 am by dpd »
