Need Recommendation for SUT
0 Members and 1 Guest are viewing this topic. Read 5054 times.
S Clark
« on: 3 Dec 2015, 03:10 pm »
I'm jumping into the low output world with a Dynavector 20x2L.  I have several phono pre options (Dodd, 2 Vistas, Graham Slee, Cambridge 650), but all but my least favorite are MM only.  Like everything in this hobby, the options for SUT run from $150 to stupid $.  Where is the sweet spot?  My usual mode of operation is to find something outside of my budget, then wait to find a used model.
Any advice?
jtsnead
Re: Need Recommendation for SUT
« Reply #1 on: 3 Dec 2015, 03:44 pm »
S Clark
« Reply #2 on: 3 Dec 2015, 04:42 pm »
You know what I am going to say, Bob's
I saw that that's what you have been using.  So $900 used is the buy in point??  I know it's hard to put figures on something like this, but is it typical to spend 1:1 for a cartridge/SUT combo?  Is a SUT more than a passive transformer in 1:6 to 1:12 range with a couple of RCA jacks attached?
I've got a modded Cambridge 650 to use temporarily( hopefully, very temporarily) until a better option comes along.
jtsnead
« Reply #3 on: 3 Dec 2015, 05:01 pm »
Yes and yes, they tend to hold their value, but you could make an offer.
I have heard that building a sut can be difficult to get the wiring right and
that Bob's is considered a really good product for the price, Once you have
one you usually keep them.
It is exactly a passive transformer, on Bob's website there is a chart
and based on that and the 20xl2 being .3mv output and a 5 ohm internal
impedance a 1:20 ratio would be best and that is what I used
Sell off some of your phono stages keep the best one you like for mm input
and put the money towards the 1131 and I think you would be very happy
S Clark
« Reply #4 on: 3 Dec 2015, 07:31 pm »
I've just dipped my toe in the water with a used cart. at $450, so tripling the investment with a Bob's SUT when I don't even know what I'm getting into...
What are the options in the <$500 range?  Anyone familiar with the K&K kits? JH audio? There's a potted SUT from Cryoparts (a Shure for around $225).  Park's Audio with Cinemag transformers?  Or should I just borrow my friends Jolida with a MC circuit? Or will all of these lower cost options hide the benefits of a low output cartridge so that I might as well stick with my DynaV 10x5 ????
rollo
  • Rollo Audio Consulting -
« Reply #5 on: 3 Dec 2015, 07:34 pm »
  Dave Slagle makes some of the best. Made in USA.
charles
woodsyi
« Reply #6 on: 3 Dec 2015, 07:38 pm »
Scott,
I will loan you a S&B 102 unit set on 1:20.  PM me if you want to try it.  I have no idea what the cost is.  I don't think they make them anymore.  I got my active phonostage and strain guage. I don't have any MM unit to mate it with.
S Clark
« Reply #7 on: 3 Dec 2015, 07:51 pm »
Scott,
Wow! How can I turn that down.  Thanks.  You've got a PM.
jtsnead
« Reply #8 on: 3 Dec 2015, 09:08 pm »
Woodsyi  :) very nice of you
Scott...that would give you a good idea of the advantages of
a sut and frankly the lower cost ones probably are 80 - 90%
of what you would get with a higher price one
S Clark
« Reply #9 on: 3 Dec 2015, 09:17 pm »
Thanks for the info. It seems that in audio, all the $ goes toward those diminishing returns... that %10 improvement.   Rim's SUT will should let hear the key difference between low and high output MC within the same family of cartridges.  I can also see how the Jolida pre stacks up on its MC setting.  Best of all possible worlds!
tubesguy2
« Reply #10 on: 3 Dec 2015, 11:09 pm »
If you're at all comfortable with a little DIY, you can buy a different transformer pair from Cinemag (the CM-1254) for $350, and stick them in a box with RCA jacks for very little. They reserve the (possibly) better version for commercial or semi-commercial customers.
S Clark
« Reply #11 on: 3 Dec 2015, 11:41 pm »
No problem with DIY up to a point.  I'll keep this in mind.
jsm71
« Reply #12 on: 4 Dec 2015, 03:15 pm »
One more  :thumb: for the Bob's.  I bought his Sky 20 to mate with my Lyra Delos going into my Cary MM phono stage.  This was my first MC cartridge after using a number of higher cost MM ones.  My listening buddies pushed me over the edge and my system warranted it.  Bit the $$ bullet for sure to make this jump but wow, I'm not going back.
As a passive component I looked at it as a long term investment, locked only into the range of gain the model I selected can support.  A good SUT into a MM stage is sweet.  Make sure you have quality shielded cables in and out of the SUT.  Good luck with this adventure.
neobop
  • BIRD LIVES
« Reply #13 on: 4 Dec 2015, 04:30 pm »
You should check out Rothwell Audio.  I don't use an SUT, but heard good things about these:
http://www.rothwellaudioproducts.co.uk/html/hi-fi.html
The MC1 costs about $425.  The MCL is about $733.
neo
griffithds
« Reply #14 on: 4 Dec 2015, 05:01 pm »
S Clark
Quote:   '' It seems that in audio, all the $ goes toward those diminishing returns... that %10 improvement.''
   I wish it was that high.  Sometimes it only 0.05% and sometimes even the word 'improvement' might not be the correct word to use!
jsaliga
  • Vinyl Provocateur
    • The Spinning Record
« Reply #15 on: 14 Dec 2015, 05:51 pm »
S Clark
I agree completely.  I used a Bob's Cinemag Blue SUT with a LOMC cartridge for about a year.  It was quite nice as far as that goes but I ended up changing to a solid state phono stage with enough gain for a LOMC and haven't regretted it one bit.
--Jerome
