BUC-1 Questions
0 Members and 1 Guest are viewing this topic. Read 1148 times.
Bert583
BUC-1 Questions
« on: 29 Nov 2015, 07:58 pm »
A few questions about the BUC-1.  Sorry, if they are very elementary.
1.)  Can I hook up a BUC-1 directly to a Krell Home Theatre Standard 5.1?  If so, what inputs do I use and what kind of cable do I use?
2.) Having done that, can I hook a computer up to the BUC-1 via the USB?  Does the quality of this computer matter as to sound quality?  For example, can I hook up a very old computer that is dedicated for this purpose?  The alternative, of course, is to get a BDP-2, which I may do.  But would this work as a stopgap solution?
3.) Can the BUC-1 connect to a wireless network?  Therefore I could stream music from the computer wirelessly?  How would this impact sound quality?
  • The Demo is Everything!
    • http://www.bryston.com
Re: BUC-1 Questions
« Reply #1 on: 29 Nov 2015, 08:09 pm »
Hi Bert
1. The BUC 1 is Digital OUT so it must be connected to a DAC using a digital cable.
2. Yes you can use an old computer and USB out bypasses the computers sound card and the quality is controlled by the BUC1.
3. No the BUC 1 does not have a wireless connection but your computer can stream that through the BUC 1
james
« Last Edit: 30 Nov 2015, 01:11 am by James Tanner »
Bert583
Re: BUC-1 Questions
« Reply #2 on: 29 Nov 2015, 10:39 pm »
James,
Thank you.  Some more follow-up questions.
1.)  Are the digital outs in stereo?  That is, they carry two channels in one cord?
2.)  Do you recommend using any particular digital out?  (Higher quality, etc.)
Herb
Re: BUC-1 Questions
« Reply #3 on: 29 Nov 2015, 10:49 pm »
James,
Herb
Hi
Yes stereo out - one cable required.
A lot will depend on the DAC you have - recommended is AES first and SPDIF coax second.
james
Starchild
Re: BUC-1 Questions
« Reply #4 on: 30 Nov 2015, 12:26 am »
The Buc-1 is a fine unit.  I forsee hours of audio enjoyment in your future.
