14 of my DIY power cables for sale
0 Members and 1 Guest are viewing this topic. Read 1751 times.
Big Red Machine
« on: 24 Nov 2015, 09:16 pm »
I'm packing to move soon and really need to lighten the load some. I have a collection of PC's from 24 inches to 11' 9" in length. I didn't build these to sell. I started with solid copper wiring for a few years and then switched to silver plated stranded and the cables just started piling up.
Purple tech flex cables are $100 each unless otherwise identified below:
The long purple cables have red copper connectors and 2X 14 ga and 2x 12 ga solid copper for hot and neutral each (4 wires each) with a 14 ga ground. One has a right angle IEC.
The middle purple cables also have red copper connectors and have the same internal construction, 5 feet with right angle iec.
The other purple next to it is 41 inches and is made of 4x solid copper 12 ga hot and neutral with single 14 ga solid ground.
The next two purple cables with Furutech golds are solid copper 14 ga 4x hot and neutral with 2x 18 ga ground and is shielded with copper shielding. 35 inches.
The 2 footer is also Furutech golds but with 2x 10 ga solid copper on all 3 nodes.
sale pending on these 2
The silver cable is polyester sleeved, Rhodium plated connectors, 6x solid 14 ga copper hot and neutral each, it has a shielded 14 ga ground that is external.  4 feet. $150
The last purple tech flex cable is 57 inches with external 14 ga ground, it is shielded and the hot and neutral are 6x solid 14 ga copper.  $150
The 6 black polyester cables:
All of these have Rhodium plated Acro-Link connectors. All of the nodes are 2x 10 ga silver plated copper Mil-spec, teflon coated wire. Each cable is very flexible.
88" 20 amp cable
108" 15 amp
44"
65"
88"
33"
$100 each, the connectors, wire, and polyester cost more than this in material costs. At $200 I'd make a small profit.
« Last Edit: 2 Dec 2015, 12:43 pm by Big Red Machine »
Big Red Machine
Re: 14 of my DIY power cables for sale
« Reply #1 on: 1 Dec 2015, 09:12 pm »
bump
DaBoss
« Reply #2 on: 2 Dec 2015, 12:34 pm »
Hi Big Red, PM sent. Dave.
Big Red Machine
« Reply #3 on: 9 Dec 2015, 04:44 pm »
bump
Big Red Machine
« Reply #4 on: 22 Jun 2016, 07:59 pm »
I'll sell the Acrolink connector pairs (the carbon fiber units) for $100 a pair (male and female AC parts) with or without the wire connected, your choice! They are $100 each new. Roll your own.
audiogurujax
« Reply #5 on: 14 Jul 2016, 06:10 pm »
PM Sent
