Recommended 32" LCD TV
0 Members and 1 Guest are viewing this topic. Read 1213 times.
Todd Willhoit
« on: 23 Nov 2015, 07:49 am »
I would like to pick up a small (~32"), inexpensive TV for a spare room.  My experience with Samsung has been quite good, so I am leaning in that direction.  A smart TV would be nice for Netflix, etc., but we can live with OTA if the price isn't right.  Can anyone offer any suggestions or point to holiday discounts?
Phil A
Re: Recommended 32" LCD TV
« Reply #1 on: 23 Nov 2015, 03:31 pm »
I've also have had good luck with Vizio.  I have a 32 inch in the bedroom when I don't use the projector and it has Apps.  I have a 29 in the kitchen and I have a very old (probably pushing 11 years) 32 inch 720p LCD in the garage, a 42 inch 1080p that is about as old as the 32 inch and a 55 inch backlit LED in the guest room that I had in the master bedroom in the old place.
srb
« Reply #2 on: 23 Nov 2015, 04:04 pm »
Can't go wrong with Samsung, but I think an even better buy is the Insignia NS-32DR420NA16 Smart 1080p on sale at Best Buy for $190.  I have a different model, but it is excellent and solid.  I'm told they are manufactured by LG, but that could vary by model.
Todd Willhoit
« Reply #3 on: 23 Nov 2015, 04:26 pm »
Thanks guys.  The Samsung I was looking at is model UN32J525DAFXZA at Costco.  A little more than I want to spend, but as I mentioned, I have a comfort level with Samsung.
Does the Insignia support Amazon Prime?  I don't see it listed on the Amazon Compatible Devices list.
Phil stated that he has a 720P 32".  What are your thoughts on 720p vs 1080P for this screen size?  Also, it appears that 32" sets generally have a 60 Hz refresh rate.  Do you notice any issues with that refresh rate and fast moving screen content?
Phil A
« Reply #4 on: 24 Nov 2015, 02:36 am »
That 720p is really old (is in the garage at the moment).  The newer 32 inch Vizio I have is 1080p.  I don't see a big issue with resolution for the screen size.  My old Vizio 42 inch has 60Hz and I've never notice an issue.  I used it for years in the master bedroom and now it just sits in a spare room.  The link to the Insignia shows it has Roku which lets you add a couple of thousand channels, including Amazon Prime.  I have a 50 inch non-smart Insignia and have a Roku 3 box with it.  All you need to do is go online to roku.com and set-up your channels.
