0 Members and 1 Guest are viewing this topic. Read 8729 times.
If you bypass the Denon phono you should be able to plug the TT into the Budgie. The Budgie then plugs into an aux input.If you use the Denon phono you should plug it directly into aux input. Check the manual to see if there are any alternate settings on the Denon phono. neo
It's not easy to diagnose long distance. It could be anything from a bad connection, to your cartridge connected out of phase. About the only thing I found out was the switch for the phono stage is under the platter, but you must know that. I assume you can still plug your 1200 into the Budgie and all is well? Where did this cart come from, use it before so you know it works? Check the wires going to the cart. Do the colors match up, and the connections tight? Check the stylus and see if it's seated properly. Not much to go on here. You can try another cart and if it still has low volume it might be defective. Is the Denon new or used? neo
You probably hit a bump on the way home with the Denon and a loose connection came apart, or something like that. Can you solder? Sometimes you can open it up and find the problem and fix it yourself if the problem is obvious. If you don't feel confident about this, you should download the service manual anyway for the tech/repair shop. http://www.vinylengine.com/library/denon/dp-300f.shtmlIt would be good to resolve this or eventually you'll wind up with a bunch of junk tables in the basement. I don't know about the Pioneer. It looks similar to the Denon - semi-auto. Same deal with the service manual:http://www.vinylengine.com/library/pioneer/pl-514.shtmlIf you take either one to a shop there's probably a minimum fee for an estimate. A big repair could cost more than the table is worth and you might have to decide if it's worth fixing. If you want basic instructions on how to open it up, just say the word. If you're lucky you might be able to save a bunch of $.I believe I mentioned some upscale semi-auto tables on the other thread. All the major Japanese companies had them. If you're looking for one good table with end of record lift, it will take some money to beat your 1200 with a Q-up, but it can be done. With any vintage table there's always the risk of needing a repair. If you could identify the problem it would shed some light on how to proceed. Hope this helps.neo
