0 Members and 1 Guest are viewing this topic. Read 4100 times.
I was intend to buy one when it was on production at more than 10y ago.Local price was 5Kusd for a new unit.Now 1K is a used one. It works w/a expensive battery, also LCD mono color blue screen wear with time and replacement are top $ as every German product and prevent the fixture due hi price.Its a marriage for entire life, hard to sell.OBS.: I would desire a Power Plant even used, it solves what the 43 detects.
I have a Fluke 43B. Used it to determine that I had power line distortion higher than everyone else I measured. Turned out to be corroded contacts in my meter base from a lightning strike in the neighborhood. Convinced the local power company with the measurements and they came out to correct the problem.Had DC that was being caused by the problem and toroidal power transformers were mechanically humming. The meter does not measure DC directly, but the distortion measurement being high showed the problem. Also helped a local audio store find a problem with their AC power with it and that is was not caused by AC power line distortion, but computer SMPS and a bad transformer.
I have two PowerPlants that don't seem to do anything for me other than act as high quality extension outlets.You're right about the price for a Fluke 43B--the price I found on line was for a used 43. The 43Bs are about $3.5k new. What is the difference between the 43 and 43B?
Rich,This is what I'm curious to find out. I have a low level (only audible when no music is playing and my head <3' from the speaker) hum from my AtmaSphere M60s that I'd like to eliminate. Plus I'd like to experience the miraculous improvements from power cords/conditioners, but so far I've heard no change positive or negative.Evan
This may not be a defective amp or energy prob,even may be a chassis cover loose, or semi loosescrew at any transformer base.
Evan,I have a PPP as well and it stopped the transformer hum. It has a low distortion output that should stop DC to the transformers.Sounds like it might be something else.
PS Audio Power Plant Premier
