Pioneer 739 CD Burner vs EAC on computer
0 Members and 1 Guest are viewing this topic. Read 3816 times.
Marbles
« on: 18 Oct 2004, 04:37 pm »
Ehider brought over a Pioneer 739 recorder so I could burn a copy of The Best Of Knuckles O'toole LP for my father.
While he was there we did a test burning a copy of Jennifer Warnes -The Hunter CD on his Pioneer and me burning a copy on my CD using EAC.
When we did the playback, we had just listened to cut 8 on the original, Way Down Deep.  We then played the 739 burned one and it sounded like the original.  Then the EAC went in and it did not sound nearly as good as the original.  We stopped the EAC burned one after only the first few drum beats and tried it again.  Again it did not have as much decay and generally sounded bad.
Both copies were newly opened Matsui CD-R music discs.
EAC was burned at 12X with no errors detected when copying to the hard drive or when burned to the disc.
JoshK
« Reply #1 on: 18 Oct 2004, 04:49 pm »
In general it is best to copy at 4x or less.  I think there is something to be said about copying this slow.
Marbles
« Reply #2 on: 18 Oct 2004, 04:51 pm »
Yup, I'll be trying different slower speeds in the future.
« Reply #3 on: 18 Oct 2004, 04:56 pm »
Yes, Josh is absolutely right, anything over 4x really loses fidelity (in my experience).
djbnh
« Reply #4 on: 18 Oct 2004, 11:13 pm »
I have not had fidelity issues using EAC at higher speeds. Additionally, I really love how EAC lets me copy/recreate older, less well cared for discs, albeit it may take the software some time to read/correct the errors.
Hopefully users of EAC are taking advantage of the software's ability to conduct offset correction...
  • Speakers....What Speakers ?
« Reply #5 on: 19 Oct 2004, 04:15 am »
9/05/04 PhilNYC....
Forgot one other thing we did (we did a lot at this mini-Rave!). Someone had a question about CD-Rs versus original CDs. We happened to have a CD-R and an original CD of the same recording (Black Light Syndrome). It was pretty clear that the CD-R had a smaller soundstage and less depth...so at least in this one experiment, it was clear that the CD-R fell short of the original CD...
This was at Phil's mini - rave....of a cdr I had burned for him at 2x's speed. You could really notice the difference. The original was alot better....sound wise. :?
BeeBop
« Reply #6 on: 19 Oct 2004, 09:36 am »
Quote from: djbnh
What does offset correction do, and how does it work?
djbnh
« Reply #7 on: 30 Oct 2004, 05:49 am »
Quote from: BeeBop
Quote from: djbnh
First off, my apologies, I thought I sent a response to this question some time ago. Mea culpa!
Here's some offset related information quoted from the EAC FAQ site:
4. Offset Questions
Q:  Is the read offset (or the write) offset drive model dependent, or is it possible that the same drive has a different offset in a different system?
A:  The offsets should be the same for all drives of that specific model. Though, it is possible (but not probable) that the offset varies with different firmwares.
Q: What is the difference between read offset, write offset and the combined read/write offset?
A: Read offsets occur on reading (extracting). Write offsets happen on writing (burning) a CD-R. Most CD record programs do not support write offsets (as EAC perhaps do not support your writer for burning). So, to create an exact (offset corrected) copy of your CD, you would have to compensate the write offset already on reading. So instead of specifing the read offset as sample offset for extraction, you would rather use the combined read/write offset. This is easily calculated by the formula: Read Offset + Write Offset = Combined Read/Write Offset
Q: What is an read or write offset? When do they occur?
A:  During extraction or writing of the audio data, nearly all CD-ROM/CD-R drives will add an offset to the position. This is usually around 500-700 audio samples (ca. 1/75 second) on reading and around 0-18 samples on writing (ca. 1/1000 second). So if a program queries a specific sector, it will not receive exactly that sector, but shifted with the number of samples of the offset.
Q: How do you find your CD-ROM's read offset?
A: There is a test routine included in EAC that will determine the offset for a drive using a library of predefined commercial CDs. It is important that you use exactly the same pressing as the creator, otherwise another offset could be occured on remastering. So you should at least receive twice the same offset on two individual CDs. If you have a Plextor 40X CD-ROM drive (or know somebody who owns one), you could even help to extend that database of included offset CDs to help others to determine the offsets. If this does not bring a good result, the last option is to ask the other persons in the mailing list if anybody already determined the offset for the specific CD-ROM drive model.
Q:  How do I determine the combined read/write offset?
A: The combined read/write offset is only valid for the special combination of exactly one reading drive and exactly one writing drive. If you use another reading, you would most probably need a different combined offset. To determine this offset, you would need to write a CD-R/CD-RW. At first prepare WAV files you want to write to the CD. Then write it to a CD (either with any burning program, or with EAC using write offset 0). Do not delete the written WAV files. Afterwards you have to extract one or more tracks from the freshly burned CD, using the specific reader and using read offset 0. Of course you should not overwrite the original WAV files. Now you have to use the WAV Compare feature in EAC to compare the first WAV (original) with the second (reextracted one). Usually EAC will report either missing samples or extreneous samples. The number that is reported by that will be your combined offset, only be changed to positive or negative. If your original file has extreneous (repeated) samples or the copied file has missing samples the offset should be positive, otherwise it should be negative. (I hope this is correct) To double check the found offset, use that offset as sample offset for reading. Now The reextracted file and the original should be the same without missing or extreneous samples.
Q: How do I determine the CD-Rs write offset?
A: At first determine your read offset, then determine the combined read/write offset. By using this formula, you will get the write offset. Write Offset = Combined Read/Write Offset - Read Offset
Q: I try to determine the offset for my CD reader using a CD from the list given on EACs homepage, but it tells "CD not found in offset database". Why?
A:  It has to be the same pressing like I used, as different pressings usually uses a different offset. This specific error occurs, when the track layout is different than the correct CD, e.g. one track is slightly longer (1 sector would be enough).
Q: I used several CDs to determine the sample offset for my CD reader, but the results of the offsets are not consistant (all the same). What now?
A: Probably you use different pressings of some (or all of) the CDs you tested. If you get at least twice exactly the same offset, you could be pretty sure to have found the correct one (and only then!).
