Review and Tech Report from Europe in HiFiTest.DE
0 Members and 1 Guest are viewing this topic. Read 1605 times.
John Casler
« on: 20 Nov 2015, 05:16 pm »
Here is an interesting review, in a European Magazine, HIFITEST.  If you want to read it use the translator function.
What is VERY INTERESTING, is the tested POWER specs for the ST-10, which shows how NuPRIME DOES NOT inflate their numbers, in fact, the very opposite.
While NuPRIME posts the Power output to be 150wpc at both 8 and 4 ohms, this bench test finds the following:
"With 205 watts per channel into 8 ohms resistor, the ST-10 yielded slightly more power than specified by the manufacturer. At 4 ohms the trace then handed the laboratory to just below 300 watts before the Klirrgrenze was achieved of 0.7 percent."
You can find and translate the review HERE
« Last Edit: 20 Nov 2015, 09:44 pm by John Casler »
rustydoglim
Re: Review and Tech Report from Europe in HiFiTest.DE
« Reply #1 on: 24 Nov 2015, 08:38 pm »
We suspect that the test was done with just one channel, which is typical of lab test.
In the real world, either the left or right suddenly draws a lot of power, but seldom both channels are equally driven.
And we use a very conservative 1% THD rating for max power (pro audio typically spec at 10%.
Therefore you can expect to get a lot more power than we specified for our products.
