Which tube tester(s) would you recommend and why?
0 Members and 1 Guest are viewing this topic. Read 1006 times.
mlundy57
« on: 20 Nov 2015, 03:01 am »
A number of times I have read references to testing your tubes before using them. How do you do that and what equipment is needed/recommended?
Mike
sfox7076
Re: Which tube tester(s) would you recommend and why?
« Reply #1 on: 20 Nov 2015, 03:25 am »
Well, I recommend a Hickok if you want to get a reliable tester for selling.  Precise 111 is a good value tester.  Building a UTracer is another option.  The last option has a bunch of plus and minuses.  The greatest being that there is no shorts or gas test.  Sigh.
Shawn
« Last Edit: 20 Nov 2015, 05:09 am by sfox7076 »
