Skiing Ninja Master x-ls Encore Monitors - Fully Custom! [No Longer Available]
0 Members and 1 Guest are viewing this topic. Read 5069 times.
The Ninja
  • Manufacturer
    • Skiing Ninja Systems
[These are no longer available]
I have for you a one of a kind pair of New x-ls Encore Ninja Master speakers.  From these speakers you can expect excellent imaging and low level detail, well defined bass, and a really sweet midrange.  They are perfect for small and medium rooms.  I've driven them with a 38 watt 5881-based tube amp and lI have for you a one of a kind pair of New x-ls Encore Ninja Master speakers.  From these speakers you can expect excellent imaging and low level detail, well defined bass, and a really sweet midrange.
They are perfect for small and medium rooms.  I've driven them with a 38 watt 5881-based tube amp and loved the sound.
These began as the prototypes for something we were internally calling "Ninja Punk". A bit Steampunk and a generous dose of Ninja. We had some really cool stuff planned for these and even have most of the components in stock for the first run.
As we have decided to close Skiing Ninja Systems (bit at the bottom as to why), we have decided to make these available as non-punk speakers with a completely custom finish.
I formulated the color myself and it is not available anywhere else. The speakers were shot in a booth with a base/clear system - and the clear is Glasurit 923-109. Those in the biz know that this clear imported from Germany is one of the top of line clears available anywhere. It looks awesome! If it is good enough for a 200+mph car, I think it will hold up nicely here :)
The X-LS Ninja Master Encore is an 8 ohm load and has 87db sensitivity. The -3db down point is 55Hz. The low 1.8kHz crossover point allows for a great driver integration and consistent phase relationship of the drivers over a wide vertical range. The vertical and horizontal off axis is excellent so the in-room response is very smooth and consistent.
The frequency response is as smooth as +/-1.5db and better than +/-1 through most of its range.
Horizontal off axis taken at 0, 10, 20, 30, and 40 degrees off axis.
Vertical off axis response shows a great phase relationship over a very wide range.
The spectral decay is also extraordinarily clean.
And the impedance curve shows a nominal 8 ohm load, and 43Hz tuning.
Images included for all of these measurements.
Driver Information
Tweeter
The T26SG is a low resonance one inch HYPERTEX Dome Tweeter made by Peerless India.  It uses an especially designed Hypertex surround material, which is light, durable & yet flexible enables for low resonance.  It uses a special hollow pole piece that provides good acoustic coupling to the rear chamber.  The rear chamber wall is formed as a concave protrusion, which prevents standing waves and increase stiffness.
Woofer
The M-165 has a curvilinear cone allowing a smooth roll off into the higher frequencies ranges.This woofer has a very smooth mid-range and great bass response. The M-165 is vented below the spider, has a bumped back plate, polymer chassis, lightweight treated paper composite cone with new curvilinear shape
Specs:
NoRez lined cabinet
Polyfill added
Ninja Master Crossover - custom layout for this pair only
Pure point to point connections - no PCB
Matched Sonicap G1 capacitors
Erse XQ Perfect lay inductors - correctly laid out to avoid crosstalk
Mills Resistors
Electra Tube Connectors
Electra Tube Banana Plugs
Electra Cable (internal) - The 15ga. conductor is solid core high purity copper (99.98%) with a 30 mil polyethylene insulator
60 durometer crossover stand offs - keeps the board from vibrating on the cabinet
Cardas Quad Eutectic Solder
These are set up basically the same as the x-ls Encore Ninja Master speakers that won the small speaker shootout at StereoMojo.com several years ago.
Now, you notice I said prototype up there. That means these aren't cosmetically perfect.
There are other small dirt nibs here and there but all very small. You can sand and polish to make those all look perfect if you like. Also, the builder of these cabinets placed the wall seams incorrectly and I didn't fix the appearance well enough before painting:
Note that it is cosmetic only and you can't see it in normal lighting.  I have 1000 watts of lighting shining at 20"!
Finally, here you can see the slight warble where the clear ran. This can be sanded and polished out if you wish but it is minor and on the back:
When we built them, they were $1000/pr in a standard finish (absolutely worth it) + $600+ in paint materials and labor = $1600/pr
Absolutely worth it at $800.
These are 28lbs each!
If I recall correctly, shipping will be around $55.
Though the business has closed, I will warranty them for three years and Danny at GR Research has has good stock of the drivers.
A note on the closing of Skiing Ninja Systems:  As you may or may not know, Skiing Ninja Systems has closed its doors. Mrs. Ninja's health continues to decline and something has to give. Skiing Ninja was open for business for around eight years and we lament its loss.
Credit: I used some text from Danny's website above...
« Last Edit: 3 Feb 2016, 12:03 am by The Ninja »
The Ninja
  • Manufacturer
Re: Skiing Ninja Master x-ls Encore Monitors - Fully Custom!
« Reply #1 on: 17 Nov 2015, 05:33 pm »
I can also do a package with an ONIX SP3:
This is a great amp that was distributed by that one company some years ago.  You can see it installed in my quasi-test system (where I would real-world test products).  It pairs excellently with the x-ls Encore Ninja Master speakers.
MSRP was $999
If you pick it up with the speakers, you can have it for $400.
There are tons of consistently positive reviews out there for this amp.
Specifications
Frequency Response: 20Hz to 20KHz
Class AB
Power Rating: 38W x 2
Manually adjustable bias
Input Impedance: 250K Ohms
Output Impedance: 4 or 8 Ohms
Input Sensitivity: 380 mV
S/N Ratio: >90dB / T.H.D – 1% (standard tube spec)
Dimensions (WxHxD): 11.9″ x 8.1″ x 13.25″
Weight: 56 lbs.
Tube Complement:
4 X 5881
X 12AX7
2 X 6922
2 X 12AU7
Folsom
« Reply #2 on: 17 Nov 2015, 09:33 pm »
I thought you stopped doing audio?
jseipp
« Reply #3 on: 17 Nov 2015, 10:27 pm »
Those speakers are beautiful!  They also make a very handsome match with the SP3.
I've, sadly, never heard any Skiing Ninja upgrades, but I've read many great comments made by very satisfied customers who have.  I can speak to the amp being offered as it was my own introduction to tubes -- looks and sounds great as well as being built like a tank.  There are tube-rolling threads out there for those who would like to experiment.
That's a wonderful looking setup being offered....
The Ninja
  • Manufacturer
« Reply #4 on: 18 Nov 2015, 12:09 am »
I did indeed.  This was the last project we were working on...
The Ninja
  • Manufacturer
« Reply #5 on: 18 Nov 2015, 12:10 am »
Thanks!  I am very sad to see these go but financial issues related to Mrs. Ninja's condition has forced my hand.
Sean
The Ninja
  • Manufacturer
Well, I can't do it.  I have to keep this combo.  I listen to them every day.  I hate cooking but with Sarah's illness, it has fallen to me.  With these cranked in my dining room/kitchen, I can actually bear it.  To hell with financial issues.  These are MINE!
:D
Sean
mlundy57
Think of keeping them as money being spent on emotional well being. You can listen while you cook but you can also listen to relaxing music and/or something like Tibetan singing bowls for calm and balance. Kinda like therapy you don't have to pay for.
Good luck
Mike
dlparker
  • Dave Parker - KC, MO
Good luck
Mike
WHOA! It's way too early in the day for me to be posting and/or trying to think. I read 'singing bowls' as 'singing bowels'. That's about the last thing I'd like to listen to for calm and balance.
Zero
Seaaan!  Other Sean here.   Not sure if you'd remember me, but I just wanted to say hello all the same!  I'm glad that you decided to hang onto the system.  Enjoy the sweet sound amigo - you've certainly earned the right to do so. :)   I hope the situation with your lady improves.
