4b sst2 matching tube pre
0 Members and 1 Guest are viewing this topic. Read 2795 times.
krbabu
« on: 16 Nov 2015, 03:00 pm »
Hi there
Any recommendations for my pre amp.  Please give me your valuable suggestion
Phil A
Re: 4b sst2 matching tube pre
« Reply #1 on: 16 Nov 2015, 03:09 pm »
There are plenty of choices - budget in mind?
Odyssey Candela is one.  I use one in a secondary system with a Bryston 3BST. Great combo.
Phil A
« Reply #2 on: 16 Nov 2015, 03:09 pm »
Backert Labs would be another moving up the price chain.
BrysTony
« Reply #3 on: 16 Nov 2015, 07:17 pm »
I use an ARC LS-27 with 7BSST2 and love the combo.
Tony
bjski
« Reply #4 on: 16 Nov 2015, 08:18 pm »
Bat 32SE with 7BSST/2
zuluwarrior0760
« Reply #5 on: 16 Nov 2015, 08:56 pm »
I have used a CAT Renaissance Pre with my 7bsst2's and it is an ideal
pairing.....
I am upgrading to 28s and staying with the CAT, although I may
upgrade it to the latest black path specs......
Any vintage of CAT Pre would be excellent.....
Ron D
« Reply #6 on: 16 Nov 2015, 09:06 pm »
As requested a budgetary figure would help but at various price points I've had success with Rogue Magnum 99, Holland HP-100, Lamm LL2 deluxe and L2-Ref, ARC LS-26 and ARC Ref-3. I know I've left off a couple from my list but there are many good choices out there and I'm sure you'll get some really good suggestions.
drummermitchell
« Reply #7 on: 16 Nov 2015, 10:03 pm »
I use a Vac pre(MKII-A) with 28s,
I'd be very comfy using the vac on 3's,4's,7's ect.
Heckler75
« Reply #8 on: 21 Nov 2015, 04:15 am »
pairing.....
CAT  Preamps  are   world class    (own  CAT Ren  Black Path)      simply  just  Amazing    :thumb:
The  CAT  Renaissance   "Black Path"   is   a total  game  changer   (bests  older CAT Legend  preamp)
if you buy one----you'll  probably never look back 8)
Cheers
RDavidson
« Reply #9 on: 21 Nov 2015, 04:42 am »
If you don't feel the need to get really spendy, I'm a fan of the Wyred 4 Sound STP-SE. REALLY tough to beat. The 6 Moons review does a great job of describing its attributes.
http://www.6moons.com/audioreviews/wyred2/preamp.html
To me, it's the gate keeper preamp on the market for overall value. I haven't heard anything less expensive truly better it in sound nor versatility. To do better, you have to spend significantly more. It's not a tube preamp, but read the 6 Moons review, and you'll understand my recommendation.
robb
« Reply #10 on: 25 Nov 2015, 05:22 am »
My Jeff Rowland Capri preamp is a great match to my 4bsst2, wired with Transparent Reference xl balanced interconnect.
