Audiocubics R-Cube 192-step Remote-controlled passive/volume $195
0 Members and 1 Guest are viewing this topic. Read 2273 times.
Freejazz
Selling Price:   $195.00, plus actual shipping/insurance and 3.0% PayPal fees in US 48, 4% Worldwide
Original Price: $350.00 (Audiocubics sell direct-only and has sold as low as $295+)
Ships from Huntingdon, PA 16652
Link to Audiocubics site and specs page: http://www.audiocubics.com/specs.html
Sorry for the weird rotated photo insert!
Selling this great Audiocubics R-Cube:aluminum remote controled add-on volume unit or single input passive preamp. Used this to add volume control to a vintage receiver and also as a passive. It is an excellent little unit and works Small wonders ... especially at its price.
From the manufacturer's description;
The R-Cube system is a showpiece stereo remote volume control with superb audio characteristics and a sophisticated minimalist look. Appearance is just as important as performance in excellent audio gear and brushed or machined aluminum enhance the R-cubes aesthetic. The cube shape satisfies the performance design goal of minimum possible total signal path and catches the eye with it's geometric simplicity.
Each R-Cube is hand crafted out of brushed aluminum, with machine-turned aluminum buttons and a single 192 color LED light indicating volume level.
... Matching machine-turned aluminum buttons are used on the handheld remote to give it visual and tactile appeal.
The R-cube is constructed with gold/teflon RCA jacks, silver/teflon wiring, triple eutectic solder and a minimum possible signal path in order to maintain maximum signal integrity throughout.
The Audiocubics R-cube system is a simple and elegant remote stereo volume control that is as much art as it is high performance audio gear.
Connecting the R-cube to your system:
For receivers and integrated amplifiers the R-cube inputs can be connected to the pre-amp outputs and the R-cube outputs can be connected to the amplifier inputs, with the bypass switch open or the jumpers removed. If there are no pre-amp outputs and amplifier inputs, a tape monitor loop can be used with the R-cube inputs connected to the tape outputs and the R-cube outputs connected to the tape inputs. For component systems the R-cube inputs can be connected to the pre-amp outputs and the R-cube outputs can be connected to the amplifier inputs or an equalizer, etc. If you use a single source of appropriate output voltage and an amplifier for a minimalist system, the R-cube inputs can be connected to the source outputs and the R-cube outputs can be connected to the amplifier inputs.
Note: There are situations where the system gain can be too high and cause clipping, such as; A CD player with selectable output of 4 volts connected to a CD input that is designed for 2 volts, connecting a standard 2 volt output CD player to line level inputs that are designed for an approximately 150mv signal, or any adjustable source with the output turned up too high. Since many amplifiers acheive full rated output with only 1 volt of input, any of these situations can cause clipping at worst or a limited useful range of volume control at best. In these cases output voltages can be turned or selected down where possible or in-line attenuators may be installed.
SPECS
MSRP $350.00 - Audiocubics has sold this for $295+
ELECTRICAL SPECIFICATIONS Bandwidth for measurements (unless noted otherwise) Attenuation Range (192 steps) Attenuation Step Size Attenuation Matching Total Harmonic Distortion + Noise (VIN = 2Vrms, f = 1kHz) Input Resistance Input Voltage Range (without clipping) Input Capacitance Output Drive Capability Output Noise (VIN = AGND, Gain = 0dB) Short Circuit Current Interchannel Crosstalk (f = 1kHz) Unity-Gain Bandwidth, Small Signal Power supply
10Hz to 20kHz -95.5dB to 0dB 0.5 dB + or - 0.05 dB 0.0002 % 10,000 Ohms 2.5 Vrms 3 pF 600 Ohm load 2.5 uVrms 50 mA -130 dBFS 10 mHz 120 VAC, 5W, 60Hz wall transformer
PHYSICAL DIMENSIONS R-cube R-cube remote R-cube power supply
3" cube 4" x 1.25" x .5" 2.5" x 2" x 1.5"
USER INTERFACE R-cube front face Volume indicator (+) Button (-) Button Remote control detector
Single LED, 192 color spectrum from Blue to Red (lowest to highest). Tactile brushed aluminum pushbutton switch, increases volume and shifts display color towards red. Tactile brushed aluminum pushbutton switch, decreases volume and shifts display color towards blue. Infrared.
R-cube rear face Pwr L IN R IN L OUT R OUT
Input jack for R-cube power supply. Left channel input, gold/teflon RCA jack. Right channel input, gold/teflon RCA jack. Left channel output, gold/teflon RCA jack. Right channel output, gold/teflon RCA jack.
R-cube remote (Mute) Button (+) Button (-) Button Battery
Tactile brushed aluminum pushbutton switch, mutes volume and changes display color to flashing blue. Tactile brushed aluminum pushbutton switch, increases volume and shifts display color towards red. Tactile brushed aluminum pushbutton switch, decreases volume and shifts display color towards blue. CR2032 Lithium
Unit is in VG+ condition, with only very minor marks
« Last Edit: 14 Nov 2015, 08:38 pm by Freejazz »
