0 Members and 1 Guest are viewing this topic. Read 5566 times.
For single RS5, the efficiency is published at 94.5db @ 8 ohm. Then for dual RS5 (in parallel apparently) the efficiency is published at 98db @ 4 ohm.
it's not efficiency ,it's sensitivity...
UL, think of it as being like adding extra light bulbs to a circuit; you use more electricity but you get more light. However, if you keep adding light bulbs (in parallel) you can eventually allow so much current to pass that things begin to overheat and finally blow a fuse or trip a circuit breaker.With speakers, adding extra drivers in parallel will give you more volume, but it allows more current to be delivered from your amp. As you add addition electrical pathways the resistance drops, extra current flows, and it's harder on the amp. Drop the resistance much below 4 ohms and many amps will blow a fuse, if your lucky.
But my understanding, and I may be wrong, is that the sensitivity is rated PER WATT. So one watt produces 94.5db in one speaker, and another 98db in a second speaker. And both use the same drivers - just difference in quantity? Thanks,UL
I think you're correct UL. And... distance factors into the equation as well. 93db/1watt/1meter, for example. So, the dual driver provides more volume for the same power. Translates as not turning up your preamp's volume control as much to get the same volume level!........Peter
I figure things I don't have to bother Louis with I can ask here...For single RS5, the sensitivity is published at 94.5db @ 8 ohm. Then for dual RS5 (in parallel apparently) the sensitivity is published at 98db @ 4 ohm.Such increase in sensitivity is nothing to sneeze at for low powered amps. More headroom from the amp.Question: 1. How is it that sensitivity for the SAME WATTAGE climbs with dual drivers? Drivers have not changed. I am not well versed with speaker design so am curious how that works. 2. Does that mean 3 drivers, 4 drivers become correspondingly more efficient? Thanks,UL
That's what I do not understand. If your preamp, or integrated is turned to the same place on the dial, with a 4 ohm load (dual drivers) you are actually drawing MORE (approximately double) current since the load is 4 ohm rather than 8 ohm. So you are not really getting greater efficiency. Rather the amp is simply putting out more power (watts) for a specific setting. So the sensitivity/efficiency stays the same rather than increase. That's why I'm trying to understand where I'm not understanding... The reason I'm asking is that I may consider low powered rigs in the future so sensitivity/efficiency matters. Thanks,UL
