x-voce resister ratings?
0 Members and 1 Guest are viewing this topic. Read 2143 times.
doug067
« on: 11 Nov 2015, 12:22 am »
Hello everyone, anyone know off hand what the resister ratings are in the x-voce?
Looks to be 2 of them. Thanks
Danny Richie
Re: x-voce resister ratings?
« Reply #1 on: 11 Nov 2015, 12:28 am »
Ooooh, Ooooh, I do. They are likely 12 watt rated. One is an 8 ohm and one is a 10 ohm.
doug067
« Reply #2 on: 11 Nov 2015, 01:46 am »
Thanks Danny. Figures I have 2-1 ohm and 2-5 ohm mills on hand.
They must be for the x-statics. ?
Danny Richie
« Reply #3 on: 11 Nov 2015, 02:05 am »
I have all of that if you need it or want to upgrade it.
doug067
« Reply #4 on: 11 Nov 2015, 02:52 am »
Yes looks like i will need them. Thinking about having you upgrade it. You have time these days?
Danny Richie
« Reply #5 on: 11 Nov 2015, 05:38 am »
I'll help you.
doug067
« Reply #6 on: 15 Nov 2015, 04:03 pm »
Good deal. I have a speaker I'd like you to look at too. I'll pm you with details when I get it together. Happen to know which curcuit takes the 8ohm and which one takes the 10ohm?
Danny Richie
« Reply #7 on: 15 Nov 2015, 06:02 pm »
The values are written on the resistors. Plus, when you order the upgraded parts I will send them with a diagram as well.
