$OLD APL HiFi DAC-S in mint condition $OLD
0 Members and 1 Guest are viewing this topic. Read 2293 times.
kiskaprince
« on: 9 Nov 2015, 11:47 pm »
I have in mint condition Alex Paychev  of APL HiFi DAC-S for sale
Check my other ad for Melody WE2688 pre
Some specs here
DAC – USB - 24x Asahi Kasei AK4399
All-solid-state stand-alone Digital to Analog Converter, Asynchronous Hiface USB interface by M2TECH2 built-in with192kHz/24bit resolution , Asynchronous upsampling working steady at 195kHz/32bit.The AKM DACs see this sample rate at all times, regardless of the input sample rate , 32bit AK4399 DACs by AKM of Japan , 12 per channel , working in special Mono mode (APL) , Lundahl Amorphous Core audio transformers and high-current output buffers , No capacitors on the signal path , No Op Amps , Infrared remote control ,
DAC – USB
32 bit / 195 kHz DAC chip : 24x Asahi Kasei AK4399
upsampling frequencies : 24/192 kHz
4 digital inputs
USB audio class 2 (24 bit / 192 kHz) – asynchronous
OEM version of M2Tech hiFace 2
Coaxial – RCA (24 bit / 192 kHz)
AES/EBU – XLR (24 bit / 96 kHz)
4 analog outputs
left & right RCA (unbalanced)
left & right XLR (balanced)
PSU
built in power supply
Specials
remote control
display
output level control High 2.0V or Low 1.0V
435 x 293 x 90 mm
7 Kg
Asking $OLD
Upgraded with latest  M2Tech2 USB module
Used for only 100hrs or less in my second setup
Thank you for looking
« Last Edit: 19 Dec 2015, 02:38 am by kiskaprince »
mr_bill
Re: APL HiFi DAC-S in mint condition
« Reply #1 on: 10 Nov 2015, 03:40 pm »
kiska - do you have any pics of the APL dac you can post?
Bill
kiskaprince
« Reply #2 on: 10 Nov 2015, 04:14 pm »
kiskaprince
« Reply #3 on: 15 Nov 2015, 06:55 pm »
couple of pictures
kiskaprince
« Reply #4 on: 21 Nov 2015, 11:57 am »
kiskaprince
« Reply #5 on: 27 Nov 2015, 01:41 pm »
I am really surprise that this awesome sounding dac is still here
kiskaprince
« Reply #6 on: 5 Dec 2015, 11:09 pm »
Bump
kiskaprince
« Reply #7 on: 18 Dec 2015, 12:25 pm »
Bump
