Yulong Sabre DA8 DSD 32bit/384KHz Dac/Class A Headphone amp/Preamp SOLD
0 Members and 1 Guest are viewing this topic. Read 727 times.
Tubeburner
SOLD. Selling my Yulong DA8 32bit/384KHz Dac which can be used as a Class A headphone amp and preamp. I am the original owner. This replaced my Lampizator Level 4 Series 4 dac and I feel the Yulong is much better. Performs flawless, plays DSD to Redbook. Nice feature is phase + or -.
Link here:
    Inputs: Optical, Coaxial and AES support 16-24bit 44.1-192kHz
    USB input support PCM 16-32 bit, 44.1Khz 48Khz 88.2Khz 96Khz 176.4Khz 192Khz 352.8Khz 384Khz DSD64,DSD128 - On Windows DSD256,DSD512
    USB input support Mac OSX, Linux with UAC2 compliant kernel
    KS/Wasapi/WDM/ASIO Drivers for MS OS XP to Win8 32-64bit
    SNR: -135dB.
    Dynamic Range: 133dB.
    THD+N: <0.0002%
    Frequency Response: 20-30KHz - 0.2 dB
    Output voltage: RCA 2V; XLR 4.2V
    Output impedance: headphone jack - 16 Ohm, rear RCA/XLR - 50 Ohm
    Left/right channel crosstalk: -135dB
    Power Consumption: <30W.
    Single ended heaphone output: 600 Ohm: 70mW; 300 Ohm 150mW, 150 Ohm: 280mW, 32 Ohm: 1W
    Dimensions: 250*180*55mm (10" W x 7" D x 2 1/2" H)
    Net Weight: 2.5kg / 5.5 lbs
« Last Edit: 10 Nov 2015, 06:13 pm by Tubeburner »
