Dirt cheep multimeter available
0 Members and 1 Guest are viewing this topic. Read 7493 times.
avahifi
    • http://www.avahifi.com
« on: 5 Nov 2015, 05:23 pm »
If you don't have a digital multimeter then here is one you should not pass up.
It measures resistance, DC and AC volts, current, and even tests transistors and diodes.
It costs all of $4.00.  I have a very similar one from Harbor Freight Tools I use for a backup that actually works quite well - same unit I think, just different color case.
Here is the link to it.  http://www.parts-express.com/3-1-2-digit-19-range-digital-multimeter-with-transistor-test--390-500?utm_source=Retail&utm_medium=Email_Newsletter&utm_content=390-500&utm_campaign=email110515A#lblProductDetails
Frank Van Alstine
srb
Re: Dirt cheep multimeter available
« Reply #1 on: 5 Nov 2015, 07:36 pm »
Unless you're ordering an additional $96 of merchandise at Parts Express shipping will cost you $6.95 for a total of $10.95 .....
but there's no shortage of cheap multimeters around ....
This one looks to be the same one from
Rakuten.com for $5.84 w/free shipping
http://www.rakuten.com/prod/digital-voltmeter-ohmeter-multimeter-tool-500v-10a/228314150.html?listingId=201070815
Or one similar to what I have with backlight and rubber cover from
Newegg.com for $8.88 w/ free shipping
http://www.newegg.com/Product/Product.aspx?Item=9SIA2HW2J16087&cm_re=multimeter-_-9SIA2HW2J16087-_-Product
Jim Hamley
« Reply #2 on: 5 Nov 2015, 08:52 pm »
randytsuch
« Reply #3 on: 5 Nov 2015, 09:37 pm »
Or $5.99 and instant gratification if you have a Harbor Freight nearby
http://www.harborfreight.com/7-function-multimeter-98025.html
But the Rakuten deal seems best since it has free shipping.
srb
« Reply #4 on: 5 Nov 2015, 09:42 pm »
The main problem with that is physically having to enter the store and endure the overwhelming stench of oily Chinese steel.  But you can also get your free LED flashlight ($1.00 value).  ;)
rajacat
  • Washington State
« Reply #5 on: 5 Nov 2015, 10:18 pm »
Anybody have a suggestion for a cheap meter that, in addition to basic multimeter functions, also measures capacity?
srb
« Reply #6 on: 5 Nov 2015, 10:38 pm »
I think that capacitance is probably the least accurate measurement function in dirt "cheep" multimeters.  Here's one for $14 shipped, but I have no experience with it.
DT9205A Handheld Digital Multimeter DMM Capacitance & hFE Test
http://www.rakuten.com/prod/dt9205a-handheld-digital-multimeter-dmm-capacitance-hfe-test/287467722.html
If I needed very accurate measurements for something like speaker crossovers I would probably bite the bullet and get something like a Fluke.
plaf26
« Reply #7 on: 5 Nov 2015, 11:17 pm »
I've had the Harbor Freight version (in a yellow case) for several years now and it works great.  Although I still occasionally go back to my 40+ year old analog VOM.
mikeeastman
« Reply #8 on: 5 Nov 2015, 11:26 pm »
I picked up 4 of the red meters from Harbor Freight and the 3 I tried went up in smoke when I tried to measure the voltage on a battery, hopefully the yellow ones are better.
lowtech
« Reply #9 on: 5 Nov 2015, 11:51 pm »
You are either very fond of birds or a bad speller (who knows, maybe both).   :lol:
mikeeastman
« Reply #10 on: 6 Nov 2015, 01:25 am »
 :scratch: :scratch:
charmerci
« Reply #11 on: 6 Nov 2015, 01:41 am »
:scratch: :scratch:
dirt cheep, cheep....
(ahem, as opposed to cheap.)
Guy 13
« Reply #12 on: 6 Nov 2015, 02:08 am »
Hi all,
I have a Craftmaster (Sears) digital meter with clamp for AC amps.
I think I paid 65 USD about 6 years ago.
I also have three or four analog models that I paid 8 USD when I was on planet Vietnam.
I use them once in a while and they all still work fine.
Actualy, I am surprised they did not blow up in my face.
I once had a Fluke meter (250 USD) that I had for many years,
but on day I've dropped it and the case broke (Even if it was supposed to be shock proof.)
them even if I glued back, the Vietnamese humidity went in and all the contact got rusted
and it died.  :cry:
Guy 13
Delacroix
« Reply #13 on: 6 Nov 2015, 02:39 am »
OK, basic question, what meaningful audio gear measurements can a typical audiophile make with one of these?
JerryM
  • Where's The Bar?
« Reply #14 on: 6 Nov 2015, 02:49 am »
mul·tim·e·ter
/ˈməltiˌmētər,ˌməlˈtimətər/
noun
noun: multimeter; plural noun: multimeters
An instrument designed to measure electric current, voltage, and usually resistance, typically over several ranges of value.
Delacroix
« Reply #15 on: 6 Nov 2015, 03:01 am »
Not what I asked......try to imagine what someone with no experience of using one of these can DO with it
/ DO /
verb: to perform or execute.
Odal3
« Reply #16 on: 6 Nov 2015, 03:44 am »
Frank - thanks for posting. Exactly what I was looking for.
stonedeaf
« Reply #17 on: 6 Nov 2015, 04:45 am »
1.) set to DC millivolt range and after you've let (most) SS amps run for 10-15 min without speakers hooked up and no input -measure DC offset. This can keep you from buying a lot of junk (otherwise known as epic restorations).
2.) Resistance (ohms scale) allows you to test phono cartridges ,tonearm wiring, speaker voice coils , - don't try and measure SUTs.
3.) tube bias measurements.
4.) Is that nice flameproof resistor just sittin there or is it still working ?
Basic service tool used more than anything else you'll find on a tech's bench.
G Georgopoulos
« Reply #18 on: 6 Nov 2015, 05:29 am »
obviously lot's of guys here are newbies,dont buy a cheap one with various ranges,buy an autoranging one,it would be easier to use and dead accurate,these things measure dc/ac mains volts, dc/ac mains current, resistance,continuety,etc.for audio signal measurements you'll need an oscilloscope,you cant do that with multimeters....cheers... :green:
Jim Hamley
« Reply #19 on: 6 Nov 2015, 05:22 pm »
OK, autoranging and:
DC voltage: 400mV ±(0.8%+3), 4/40/400V ±(0.8%+1), 600V ±(1.0%+3)
AC voltage: 4/40/400V ±(1.2%+3), 600V ±(1.5%+5)
DC current: 400/4000'A ±(1.0%+3), 40/400mA ±(1.2%+5)
AC current: 400/4000'A ±(1.5%+5), 40/400mA ±(2.0%+5)
Resistance: 400ohm ±(1.2%+2), 4k/40k/400k ±(1.0%+2), 4Mohm ±(1.2%+2), 40Mohm ±(1.5%+2)
Capacitance: 4nF, 40nF/400nF/4µF/40µF ±(4.0%+3), 100µF ±(5.0%+10)
Frequency Hz: 99.9Hz/0.999kHz/9.99kHz/99.9kHz ±(0.5%+3)
For under $20 with same day delivery available
http://www.amazon.com/Etekcity-MSR-P600-Digital-Multimeter-Capacitance/dp/B00NWGZ3A6/ref=dp_ob_title_ce
