I cant make as nice a picture as Tommy did above, but here's a configuration for Apple people.iMac -> itunes -> Halide Bridge USB-to-SPDIF -> DAC DAC -> DAC Marschino Amplifiers -> Speakers =
Where's the volume control?
Done digitally before the DAC. Thanks for your post.
How is the Volume controlled digitally? If done in the squeezebox you are removing data and that is a major loss of sound/quality or should I say Quality/sound.Alan
Okay you have me beat for tech. I looked this whole debate over and it was discussed here on AC a while back and my first line answer of Google search pulls up WIKI Logitech Squeezebox and they say DON"T DO IT. There is also a long and old postings on Slim Forums and a few associated sites. It was reading these sites a year or two back that I came to the Non digital Volume thought.I also did a month or more home test to see what I thought of my setup and no Pre Amp Squeezebox to Amp section of a NAD 7400 and another SS amp also. First of all the Digital Volume is Fast so don't drop the dammed remote in the side of the chair cushion.DON'T ever trust that the last person turned the volume down before they shut the equipment down.And with about four of us listening for a few hours we truly thought the sound sucked. Dead lifeless at low volumes. We even ran the Squeezbox into a couple DAC's and no real help.Just my summer of playing a while back. I personally hopped it would work as I am looking for the least amount of color added to the recorded material for what I can afford I might ad.Alan
I think there's a distinction between what the squeezeboxen would do with a 16 bit signal (start losing data right away upon digital attenuation) vs. what JRiver would do w/ a 24 (or more) bit signal where it can toss bits without significantly reducing quality.I don't know much about the math behind it (obviously!) but I've been told that when a 16 bit word is processed via a 24 bit system that 8 "placeholder" bits, w/ no information, are added and that these placeholders can be removed to attenuate w/out data loss. Tommy, could you add some different gain levels to the output of the DACDAC so that one has the choice of how much digital attenuation to use? But then why not go one step further and use analog volume? (At no additional cost to the consumer he he ).I am wary of putting 16 bits of digital ones through my Maraschinos straight to my Revels!
Had a Squeeze Box 2 (SB2) years ago but the glitches were insufferable. Anyway, do we need a separate thread to discuss non SB sources?Getting lost in undefined abbreviations (DNR, TL version DACDAC, DACDAC HS version). As an open discussion, please define.I’m all about simple and short, in fact I removed the binding posts from my single driver speakers just to get a more pure connection. With many audiophiles using computer sources why not have a built-in USB/SPDIF converter at least as an extra cost option so we can save cable/connectors, and trying to find the optimum converter (that you or a 3rd party should be able to build in cheaper)?Regarding software based volume controls:- Between maximum listening levels (jazz/classical being 105 dB) and a typical quiet noise floor of say 35 dB, we need about 70 dB of headroom- The theoretical max headroom would be about 100 dB (difference between the threshold of pain being roughly 130 dB and a really quiet room of 30 dB)- Redbook and higher resolutions have those numbers covered, as do any modern DAC, so not an issue- Speaker efficiency and proper pre/power amp matching (nearly all of which use a standard 2 volt signal) are also not at issue - But like Alan, I’ve experienced severe compression using now ancient digital volume controls- Tommy mentioned 50 dB headroom between 32 bit software based volume controls and 24 bit material (this appears to not be enough)- But what playback software has 32 bit volume controls?- Don’t know about most readers, but a short/simple slide control is not particularly easy/friendly to use- And what is the actual bit rate that readily available music actually use? (I’ve read it’s 18.5 and of course Redbook being 16 bit based would be lower.)- Thus, if my math is right, 32 bit – 18.5 bit would provide over 100 dB of headroom before clipping so that should be enough (for now)So it seems to me that the real solution is to verify which softwares have 32 bit based volume controls (hopefully with some sort of fine adjustment and numerical dB display available).
