Most firmware and software for these converters is created and supported by third-party companies. I get mine for my Off-Ramp 5 product from m2tech. It took a while for them to offer the driver for Mavericks on Mac, but it eventually came. The latest generation of converters is mostly XMOS based and I have one of these too (Off-Ramp 6), so no drivers needed for Linux or Mac. Driver needed for PC though. Sound quality with these converters depends primarily on the design of the converter, but also the computer playback software, USB output quality, cables and the power quality. I offer a really low noise fast reacting linear supply for my converters, as well as USB filters and a killer inexpensive S/PDIF cable to insure good results. These really improve things a lot.This is why so many have bad experiences with USB. It is best to go with a full-service company rather than buying an inexpensive Chinese box. Its a system solution, not just a component, so we provide the advice and ancillary products needed to get there.BTW, Dell makes one of the worst USB outputs for audio playback, at least in the past. They have too many layers of I/O bridges to get out the USB port because their machines are designed too cheaply. I highly recommend going with MAc. Mac playback software is usually better and the USB ports on the Mini are excellent. Even with the Mini you need to select the RIGHT port, not just any port. I have found the Oct 2009 mini to be the best sounding and can be externally powered from an improved supply without needing modding. It. can be purchased cheaply used on ebay. This is only one example of optimizations that can be done to improve SQ with USB. If you must have a laptop, then macbook pro is a good choice.Here are some more tips:http://www.empiricalaudio.com/computer-audio/http://www.empiricalaudio.com/computer-audio/recommended-systemsSteve N.Empirical Audio
Are you saying you can't find a DAC with a USB input? How many USB inputs on your Dell computer? Does it have TOSLINK? How long is the S/PDIF cable? What is the USB converter used for?
Thanks for your post, Steve. We're considering the Peachtree X1. We don't wish to be involved with the USB part.Fortunately I haven't had any quality issues with the Dell tablet I'm using for a "minimalist" demo system, that is ---- when it works, it works. It's getting it to work that's painful. Once it does, the data gets there. The S/PDIF receiver is very jitter tolerant, and re-clocks the data. Playing a test signal (WAV file played on WMP) out of the USB into the NuForce box, then through the DAC DAC, into the audio analyzer, I get the same THD+N performance as with the S/PDIF from the analyzer itself. Maybe Dell improved their hardware, but this Latitude 10 is something like 2 years old. Yes, I'd rather a Mac, but this system was to demonstrate low $. I need to start a thread about it. Great learning experience.On the flip side, I have a Squeezebox Touch (yeah, can't get them anymore) with coax S/PDIF-out in another demo system. Wonderful performance, and no USB woes!I checked out your products, by the way. Very NICE. We should talk about possible collaboration! I'll send a PM. Thanks again.-Tommy O
Tommy - the problem with even the best audio analyzers is they don't measure jitter very well. Music Jitter has a frequency and distribution component that is more important than just looking at the effects of jitter with a test signal on the output signal etc... I use real music data and make a direct digital distribution measurement. I have found this to correlate better to what actually sounds good.Collaborations are good. Contact me and I'll do my best to help.Thanks,Steve N.Empirical Audio
So, who has tried any of the other USB to SPDIF boxes?
I have always wanted to try the Halide Design Bridge or the Audiophilleo2, both have received very positive reviews but lately money is budgeted for other things so I have been using a KingRex UC192 converter (discontinued). A firmware upgrade transformed the UC192 into a UC384 and the new Windows drivers produced a huge leap in clarity. The change is so significant that I can now highly recommend the KingRex UC384 as a terrific affordable USB-S/PDIF converter at only $295.00. I also added a linear regulated power supply (Acopian) which brings it into the realm of amazing for the money spent.Wayne
Steve,I'll contact you separately regarding collaboration.One of my analyzers has all kinds of jitter measurement, including music sourcing. AP claims amazing accuracy, and I believe the measurements.We're touching on the subject of feedback, and not the kind used in circuit design, although that's an interesting analogy. Feedback as in "What was the effect of a given change to the system?". This is the feedback that allows continually improving results. I'm a huge fan of combining bench measurements (must be done RIGHT) and listening tests (tones, music, more music). There's a lot of detail in the explanation, which I'll provide upon request.Thanks for your kind post.-Tommy O
In the meantime, I purchased several other USB-to-SPDIF converters, and all have worked so far. More on that later....
Another USB converter that intrigues me is the WaveIO, it is an XMOS based board with I2S and S/PDIF output. A friend uses one in his DDDac (by Lucian Luckit)The WaveIO is the red board in the upper right hand corner<image>And it can be used in a stand alone USB converter using the S/PDIF output. Add an affordable linear regulated power supply (a used Acopian for $35) and you're in Cheap and Cheerful territory because the board is only €99.00 (EUR)http://luckit.biz/<image>Wayne
Wayne,Way cool. Looking into this. Actually, skipping over the I2S-to-SPDIF and back would be nice. Thanks!-Tommy O
Another USB converter that intrigues me is the WaveIO, it is an XMOS based board with I2S and S/PDIF output. A friend uses one in his DDDac (by Lucian Luckit)The WaveIO is the red board in the upper right hand cornerAnd it can be used in a stand alone USB converter using the S/PDIF output. Add an affordable linear regulated power supply (a used Acopian for $35) and you're in Cheap and Cheerful territory because the board is only €99.00 (EUR)http://luckit.biz/ Wayne
