0 Members and 1 Guest are viewing this topic. Read 5894 times.
It's not the amp.I grounded the pre-amp to the wall socket. Now, it's simply a slight buzz that fades away - only after I turn the pre-amp off. No buzzing on turn on. I think I can live with it?
You should turn off the amp first wait about a minute or so for the caps in the power supply to bleed down and then turn off the preamp.Turn on procedure, front end >>> preamp >>> Amp last.Turn off procedure, Amp first >>> preamp >>> front end.
I do that turn on/turn off procedure normally.The situation now is - with the amp on and the preamp off. There is a slight buzzing out of both speakers. (Yes, I changed cables - though all I have now is two sets of the same boutique brand.)If I turn the amp off and then as I turn the preamp off, that buzz occurs until the preamp or amp stops sending the signal.If the amp is on and then I turn the preamp on, the buzz occurs for about 5 seconds and then it quickly stops.It's a Tempest ss pre-amp.
The cables are Soundsilver Purity interconnects. (http://soundsilver.tumblr.com/)
The pre-amp does have a tape loop circuit - I'm assuming that means just having tape in/out.The cables are Soundsilver Purity interconnects. (http://soundsilver.tumblr.com/)I'm going to leave the pre-amp on for now and see if that helps.I live downtown (small town really) and I can faintly hear a radio station coming out through the speakers - though there is no tuner hooked up.
Do you have a radio transmitting antenna tower close to your home?What are you using for a front end source? Turntable/ phono cartridge? CDP? Both? Please explain. If turntable disconnect the phono ICs from phono RCA inputs of preamp, set selector to another input on the preamp and check for the radio station.Post back your findings.
From your provided Link.Each conductor is housed in an individual Teflon tube in a braided configuration to lessen EMI (Electromagnetic interference) and to prevent crosstalk between the conductors. This configuration dramatically increases soundstage, delves into the most intricate musical passages, and offers an exceptionally silent background.
The slight remaining buzz is probably noise pickup from your essentially unshielded interconnect cables.As suggested above, try a simple set of true coax shielded interconnects replacing your twisted pair boutique ones.Buzz when turning on preamp into energized power amp strongly suggests you should follow good system saving practice:Power amplifier on LAST. Power amplifier off FIRST. This prevents turn on or off transients from line level equipment from getting through the amplifier and into your speakers.Which AVA amplifier are you using?Frank Van Alstine
