0 Members and 1 Guest are viewing this topic. Read 3425 times.
HiI have been trying to make tube amps more linear,using negative feedback,there is no way i can think of to achieve that,no way,period,even tube amps that use nfb are misleading,face it,tubes are very nonlinear devices,the magnitute of high voltages and resistances make linearisation impossible,couple that with low transconductance,render nfb useless,so tubes are just that nonlinear,good or bad,that's what i have found out,since you can't do anything about it,one should use them as they are,using simple biasing etc,the reason i'm posting this is i want to know if others know something i don't,so please share here any technique that makes tube more linear or just comment on what i just posted..cheers
this is for my friend Steve with all the secretsthe tubes use a resistor load amplifying voltagebecause of the low transconductance of the tubethis generates distortionno matter what the input z is at the other endwith ss we use bootstrap or current source for amplifying voltageand of course the higher transconductance of ssthis lessens distortion + huge nfb even morei have spent a few years with tubessteve have you done ss at allcheers...
