BP26 DA info
0 Members and 1 Guest are viewing this topic. Read 1351 times.
tipatina
BP26 DA info
« on: 1 Nov 2015, 10:22 pm »
Hello, Is the DAC in the BP26-DA equivalent to BDA1 or BDA2. Is it upgradeable? Thanks
saveloy
Re: BP26 DA info
« Reply #1 on: 2 Nov 2015, 12:29 pm »
No, it uses a single chip set, as opposed to one per channel in the BDA-1 & 2.  I don't believe it is upgradeable either.
Kyri
  • The Demo is Everything!
    • http://www.bryston.com
Re: BP26 DA info
« Reply #2 on: 2 Nov 2015, 01:29 pm »
HI
It is a Crystal DAC but only has resolution up to 48K which is OK if CD quality only is required.  It is not upgradable and I usually recommend going with the BDA2 if you want full 192 resolution capability.
james
alexone
Re: BP26 DA info
« Reply #3 on: 2 Nov 2015, 07:01 pm »
...sure that the BP26 DAC can 'only' do 48 khz? i thought it was 96 khz maximum...?!?
al.
Re: BP26 DA info
« Reply #4 on: 2 Nov 2015, 07:02 pm »
al.
Some of the later units were.
james
alexone
Re: BP26 DA info
« Reply #5 on: 2 Nov 2015, 07:08 pm »
...wait, wait ---- are you saying that some are 48 and some are 96? if so then why?? and what is the current status for the dacs of the BP26???
al.
Re: BP26 DA info
« Reply #6 on: 2 Nov 2015, 07:16 pm »
al.
It was a while ago and I believe BP25's were 48 and BP26's were 96.
james
