Can I use LMS with PS Audio DS DAC + Bridge
0 Members and 1 Guest are viewing this topic. Read 2469 times.
Hear Clifford Brown
« on: 1 Nov 2015, 07:57 pm »
Been using a Modwright Transporter for about 5 years to stream from an iMac with attached 2 TB HD.  The software is Logitech Media Server (LMS) on the iMac with Squeezepad on an iPad to control the Transporter.  Cat 5 cable connects the iMac to the router in one room and from the router to the Transporter in the music room.  Next week I'll have a PS Audio DS DAC with the bridge.  Can I continue to use LMS with the Bridge or will I need to install something like JRiver?  I just want to keep it simple and JRiver seems complex (based on my reading) although I might grow to appreciate some of it's features.
I found this topic
http://www.audiocircle.com/index.php?topic=133790.msg1419463#msg1419463
and don't completely understand everything said in there.  Specifically "there is now a client app/player called Squeezelite that will also run on Linux in lieu of needing a hardware based wireless Logitech player."  Does this mean LMS only works with a hardware Logitech player, but no worries because Squeezelite will work, and maybe with the Bridge?
Hear Clifford Brown
Re: Can I use LMS with PS Audio DS DAC + Bridge
« Reply #1 on: 1 Nov 2015, 08:41 pm »
Just did a search and found that "Squeezelite is a small headless squeezebox emulator for linux" so since I don't have a linux server guess I won't be using it.  Still wondering if LMS will work with the Bridge.
holzohr
Hear Clifford Brown
« Reply #3 on: 7 Dec 2015, 03:13 pm »
Hi Mario,
I have the plugin and it is working very nicely.  I'm Jeff on the PS Audio forum where we were discussing this.
holzohr
« Reply #4 on: 8 Dec 2015, 05:01 pm »
Hi Jeff!
Nice to meet you here.. lol.
Glad to hear that the plugin is working nicely. May I ask where is your LMS running, what plattform?
With the LMS on my Synology DS212+ the plugin doesn't want to work. Not matching architecture I guess. I must read the complete thread, maybe there is a trick to fix it.
Hear Clifford Brown
« Reply #5 on: 8 Dec 2015, 06:31 pm »
My LMS is running on an iMac.  External HD dedicated to music files attached with Firewire.  I use dBpoweramp to rip CDs with this external CD / DVD burner attached with Firewire:
http://eshop.macsales.com/item/OWC/MR3F82SD24S/
The iMac connected to router with Cat5 and a long Cat5 cable goes from the router to the PS Audio DS DAC with installed Bridge I in the music room.  Use Squeezepad on an iPad as a controller.  I ordered the Bridge II couple days ago, hope with it installed the network continues to work smoothly.  Prior to getting the LMS plugin working, I was using the trial version of JRiver on the iMac and JRemote on the iPad.  There are 3 days left on the JRiver trial.  For my purposes currently I don't think I need JRiver, so might not spend the $50 to keep it.
My router is actually an Apple Time Capsule which is a combined router and backup device.  It backs up everything on the iMac as well as the external music HD.
In the future I may get a Synology NAS and use MinimServer installed on it.
