FS: Audience AR6-T passive power conditioner
0 Members and 1 Guest are viewing this topic. Read 1851 times.
polyglot
« on: 28 Oct 2015, 09:08 pm »
Audience AR6-T, checked up by Audience a year ago (still under warranty). Asking $2,150
The best passive power conditioner as it has separate filtering per each individual outlet -most power conditioners do not have this important feature-, a ground bar to lower the noise and increase the PRAT and a new version of the caps for a silky smooth yet very clear sound.
Plenty reviews. a.o at
http://www.stereotimes.com/acc091409.shtml
http://www.dagogo.com/audience-ar6-t-power-conditioner-review
http://www.ultraaudio.com/equipment/audience_adeptresponse_ar6t.htm
Comes with powerE cord, upgrade possible to NordOst Vahlla 1.5m for for just $500 more (recommended).
Please note that this is a 110V model, upgrade to the 220V version is possible (about $400 charge by Audience) Audience AR6-T, checked up by Audience a year ago (still under warranty).
Plenty reviews. a.o at http://www.stereotimes.com/acc091409.shtml http://www.dagogo.com/audience-ar6-t-power-conditioner-review http://www.ultraaudio.com/equipment/audience_adeptresponse_ar6t.htm
Check my feedback as polyglot_ny on Ebay and polygot on the Gon, AA and USAudiomart
« Last Edit: 7 Nov 2015, 07:02 pm by polyglot »
abernardi
Re: FS: Audience AR6-TS passive power conditioner
« Reply #1 on: 29 Oct 2015, 05:09 am »
Price?
ACHiPo
Re: FS: Audience AR6-T passive power conditioner
« Reply #2 on: 8 Nov 2015, 12:00 am »
Why are you selling?
polyglot
« Reply #3 on: 10 Nov 2015, 03:39 am »
upgradeitis: AR6-TSSD and a better DAC (any partial trade for the PS Audio DSD or Bricasti M1 or Lampi L4 or higher with volume control would be considered).
So the question begs: why Audience adeptResponse? In my systems (3 down from 4), I have 3 dedicated 20A lines and tried both active and passive power conditioning over a protracted period of time (yes, they still make a difference on dedicated lines).
1. Audience adept Response are passive, using filters, caps and some models have shielding and dampening materials. No restriction in dynamics, no restriction in current drawn. YMMV
2. Ground bar. We see many manufacturers coming up with ground boxes, some as expensive as $4k to improve the sound (lower background noise, better dynamics, etc). Audience has it since 2008 in their adeptResponse power conditioners AR6 and AR12 series so all the hooked up devices have star grounding.
3. Individual filtering per socket. Most power conditioners -both active and passive models- have no separation (some have at socket pair level) at all which means dirty power from one device affects another which simply does not make sense unless you plug in only one device.
Just search for images online on inside of the units (I have all of passive ones and a good deal of active ones). What you see is what you get!
« Last Edit: 10 Nov 2015, 05:02 pm by polyglot »
polyglot
« Reply #4 on: 15 Dec 2015, 03:49 am »
bump
