0 Members and 1 Guest are viewing this topic. Read 6929 times.
Have solid state mono block amps, looking for a preamp. would like some input, tubed or solid state? with a phono stage or keep that separate? Which preamps do you like?
How about the pro's and con's of passive pre amps
Don't bother with a passive preamp. They sound exactly like what they are -- lacking power.
Passive preamps:pro'sLess parts = less $$$Can be very transparent for the money.Con'sCan lack Pace, Drive, Dynamics and Soundstage size.Can be difficult to system match.If you have the budget, a high end active Preamp can add a lot of magic to your system.
You've tried all of them?
