DD to PCM
0 Members and 1 Guest are viewing this topic. Read 1634 times.
Folsom
DD to PCM
« on: 20 Oct 2015, 09:33 pm »
Hi guys,
I need to take DD to PCM. I'm trying to use DAC with cable box. The cable box says it can output PCM under the menu I selected it. Well it's a flat out lie. It's not PCM....
« Last Edit: 20 Oct 2015, 10:51 pm by Folsom »
srb
Re: DD to PCM
« Reply #1 on: 20 Oct 2015, 09:40 pm »
Optical or Coaxial?
Folsom
Re: DD to PCM
« Reply #2 on: 20 Oct 2015, 09:41 pm »
coaxial
aldcoll
Re: DD to PCM
« Reply #3 on: 20 Oct 2015, 11:00 pm »
Might  I ask who's cable and what box?
My comcast digital out of my current box is static.   I will changing boxes next month and I will be present so I hope this will be corrected. :scratch:
Folsom
Re: DD to PCM
« Reply #4 on: 20 Oct 2015, 11:19 pm »
Charter, it's the DHC6200.
I've been searching the net on the subject. Some say that Verizon's service disabled PCM out. I haven't anything else useful.
Phil A
Re: DD to PCM
« Reply #5 on: 20 Oct 2015, 11:59 pm »
That could be right from this thread - https://forums.verizon.com/t5/Fios-TV-Technical-Assistance/PCM-Audio-from-set-top-box/td-p/15199
Phil A
Re: DD to PCM
« Reply #6 on: 21 Oct 2015, 12:04 am »
I've also seen devices like these (Geffen makes one) - http://www.amazon.com/Panlong-Optical-Toslink-Coaxial-Converter/dp/B00ANIIY9I/ref=sr_1_1?s=electronics&ie=UTF8&qid=1445385693&sr=1-1&keywords=digital+audio+decoder
The problem is the output is analog.  Does the TV have an analog input and can it take that to toslink out?
Phil A
Folsom
Re: DD to PCM
« Reply #8 on: 21 Oct 2015, 01:29 am »
Well it's useless to convert to analog in a box that's a few dollars, when the goal is to have the world class DAC do it.
That splitter box would work except then I have to convert the Toslink to coaxial... it's nice that it has two channel output (PCM).
