0 Members and 1 Guest are viewing this topic. Read 2389 times.
if you count the value of your time at anything above $0.
I have enjoyed setting up my own linux based system. If you haven't tried any of the available linux server solutions, I recommend that you try one out first on an old computer that you no longer use before investing in any new hardware - make sure you like the gui, etc. first. As you may know, linux requires a bit of tinkering to get to work.
I never bought any specific hardware other than an USB DAC since I was only playing around with it, but I have now moved on to a raspberry pi2 solution. It probably will not be as good as some high end systems with expensive parts and PSUs, but I have to say that I'm more than impressed so far.
BTW: If you go for non raspberry pi solution: You don't need special soundcard if you use USB. Just make sure that the USB DAC is supported by linux (alsa)
If I decide to go the raspberry pi solution, what sort of special soundcard would I need? This will be feeding a USB DAC, so I can leave SPDIF out of the system if need be.
Unless you really like tinkering with computers and building your own, that's the best option at that budget - or perhaps a Bluesound Node 2. Nothing around that price your likely to build yourself is going to sound better. With the Aries Mini I'd try to experiment with a linear power supply that you can source form $70+ off eBay. It's tempting to think you can do better for less - and I've been down that road - and the answer is a definitive "no" -mparticularly if you count the value of your time at anything above $0.
I actually do like to tinker with computers and build my own. I pulled the budget out of thin air, so I had no idea if it was reasonable. What would you expect a good decent build to cost? Where could I start to tackle my own build?
Also, is it crazy to try to put so many duties on one box?
Here's a guide to get started: http://www.computeraudiophile.com/content/638-geek-speak-raspberry-pi-hifi-here/but I'm using moode instead of volumio since I like the user-interface better (but they are very similar since they are based on the same core). Moode/volumio is pre-configured to pretty much most thing you need and most things can be set via the web based user-interface. In other words, you don't need to configure mpd,sambashares,airplay, dlna, etc. from scratch.http://moodeaudio.org/
