Ferro fluid in tweeter and midrange driver.
0 Members and 1 Guest are viewing this topic. Read 2974 times.
andycsb
« on: 19 Oct 2015, 05:53 pm »
Hi Guys,
What usually happens to SQ if the ferro fluid has dried up or partially dried up? Distortion, lower output and/or change in sonic character?
What's the probability of tweeter and mid driver of BOTH speakers having exact same symptoms and degree of change at the same time?
Thanks.
Letitroll98
  • Too loud is just right
Re: Ferro fluid in tweeter and midrange driver.
« Reply #1 on: 30 Oct 2015, 03:02 am »
A bit of a guess here, but ferrofluid is used to cool the voicecoil and damp the suspension, so one could assume that losing cooling could cause any amount of damage large or small.  And an under damped suspension might sound brash and/or peaky.  So the takeaway is that they probably sound a lot worse than they should.  Of course your story could be that they sound no different.   :wink:  Why both drivers throw up at the same time, no clue.
Duke
    • http://www.audiokinesis.com
« Reply #2 on: 30 Oct 2015, 05:38 am »
Ferrofluid tends to smooth the driver's impedance peak at resonance, that's one of its advertised advantages and you can see it in the smoothness of the resulting impedance curves.
But if the ferrofluid is either lost for some reason or dries out over time, the driver's impedance peak at resonance will increase in magnitude considerably.  This is a problem because the crossover will have been designed based on the original smoother impedance curve.  As a result, the crossover may well fail to adequately attenuate the driver's output in the region of that impedance peak, degrading the frequency response and/or power handling (which already took a hit when we lost the heat-transfer benefit of the ferrofluid).
Of course the ferrofluid is supposed to stay in the magnetic gap, but in my opinion it is possible for the particle motion within the ferrofluid to occasionally give a particle enough energy to escape the magnetic field.  And if that happens once, it can happen again, and again.  Think of it being like a "rogue wave" in the ocean, where the prevailing weather conditions don't add up to a 70-foot wave, but sometimes waves just happen to combine in-phase and it happens.
And of course the ferrofluid is not supposed to dry out, but what happens if it gets very hot?  Does that change its physical properties enough that it is now more prone to drying out and/or being ejected from the magnetic gap?
I do a fair amount of work in the prosound world, and am unaware of any prosound drivers that use ferrofluid.  In prosound heat management is a big issue, so you'd think it would be used quite a bit, unless it had some downside.
I don't use drivers with ferrofluid for these reasons.
Tyreman
« Reply #3 on: 30 Oct 2015, 10:45 am »
I emailed to B&W  weeks ago about ferrofluid and they said that ferrofluid only dries out thru excessive power to the speaker or air getting in and drying it out
They specifically hadn't had  issues with matrix 800 series as yet.
andycsb
« Reply #4 on: 1 Nov 2015, 03:57 am »
Thanks Guys!
