Peak power/current consumption of BP26/MPS2 + 4Bsst2
0 Members and 1 Guest are viewing this topic. Read 1503 times.
Gibalok
  • Metrum Pavane/Manley Shrimp/4BSST2/Penaudio Cenya
Hello,
Here is info from manual on 4bsst2: 2 channels @ 300W into 8 ohms: 1280 Watts Max. Heat Dissipation: 2320 BTU/Hr.
I have a power system based on separate transformers of 500 Watts + 1700 Watts , so I need to know is it enough for PB26/MPS2 + 4Bsst2 (acoustic is 8 ohms PMC twenty 22) correspondingly and doesnt limit power consumtions at peaks.
Usually im using 5-10% gain on my BP26/MPS2 + 4Bsst2 + PMC Twenty 22 for normal listening running in balanced mode.
« Last Edit: 17 Oct 2015, 02:33 pm by Gibalok »
Gibalok
Re: Peak power/current consumption of BP26/MPS2 + 4Bsst2
« Reply #1 on: 18 Oct 2015, 05:34 pm »
Dear James,
Please find a minute :)
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 18 Oct 2015, 09:04 pm »
Dear James,
Hi
Please email Mike at Bryston - [email protected]
james
Gibalok
« Reply #3 on: 19 Oct 2015, 01:34 pm »
Done. Thanks
Gibalok
« Reply #4 on: 24 Oct 2015, 10:59 am »
Well, mike is not respending :((
« Reply #5 on: 24 Oct 2015, 11:28 am »
Hi
Mike was not around this week - I will forward this and he should be able to get back to you next week.
Generally a single 15 amp circuit will deliver 3600 watts of power so it seems you are well within that.
james
Gibalok
« Reply #6 on: 24 Oct 2015, 11:35 am »
3600 watts is well above 1700 watts transformer.. The problem is that im not sure we are on the same page in techical terms..
Hope to get Mike answer. I posted him photos of power system.
« Last Edit: 24 Oct 2015, 06:04 pm by Gibalok »
