What rack is this?
0 Members and 1 Guest are viewing this topic. Read 2322 times.
Kenneth Patchen
  • Just like that bluebird
What rack is this?
« on: 15 Oct 2015, 01:31 pm »
The answer should be well known to me by now ... but it isn't. Any help? (Image posted on A'Gon.)
KP
JoshK
Re: What rack is this?
« Reply #1 on: 15 Oct 2015, 02:52 pm »
Google image search brought me to this CAM member's page.   I might guess it is custom made but you might ask him.
http://www.canuckaudiomart.com/view_userimages.php?user_id=10987&image_id=4993
Kenneth Patchen
« Reply #2 on: 16 Oct 2015, 03:10 am »
Thanks Josh. I'm not active on Canuck Mart but I am on A'gon. I'll try contacting him there.
Cheers, KP
Delacroix
« Reply #3 on: 16 Oct 2015, 03:36 am »
looks sort of Walker-ish
JoshK
« Reply #4 on: 27 Oct 2015, 03:19 pm »
Did you ever find out?
Kenneth Patchen
« Reply #5 on: 27 Oct 2015, 11:04 pm »
No, Josh, I haven't, not yet. I did email him at A'gon. If I get a response I'll let you know.
Cheerio,
KP
mcgsxr
« Reply #6 on: 27 Oct 2015, 11:36 pm »
It resembles a DIY Flexi done by someone good, and using sleeves over the threaded rod typically used for the columns.
Canuckaudiomart member smally21 has made stuff for me, he is close to Toronto.  My custom flexi was something altogether different - a pint sized version 1/2 the normal size.  It sits beside my full size flexi, the smaller one is for my dedicated netbook, USB drives, DAC, and power supplies etc.
Good fun!
