First dip
0 Members and 1 Guest are viewing this topic. Read 2304 times.
SSM
  • formerly 'conrad-Jin'
First dip
« on: 14 Oct 2015, 02:16 pm »
Hi fellow audiophiles,
This is my first post, so the user interface is all new to me. :) I've been lurking and reading the threads for about six months and got registered so I can seek advice about speaker upgrades. My worklife is busy, so I'm going to be a low-profile member. 8)
Jin
JerryM
  • Where's The Bar?
Re: First dip
« Reply #1 on: 14 Oct 2015, 02:41 pm »
Welcome to AudioCircle, Jin.  :beer:
4Play
  • You Get Busy Living or You Get Busy Dying
Re: First dip
« Reply #2 on: 14 Oct 2015, 02:44 pm »
From another new member, welcome to AC!!
mcgsxr
Re: First dip
« Reply #3 on: 14 Oct 2015, 02:46 pm »
Welcome to the fun.  Its a great place to spend some time!
SSM
Re: First dip
« Reply #4 on: 14 Oct 2015, 03:24 pm »
Thank you, gents! :D
Jin
mresseguie
Re: First dip
« Reply #5 on: 14 Oct 2015, 03:53 pm »
Hello, Jin.
By all means ask questions. There's so much knowledge floating around on AC it stuns me sometimes.
SSM
Re: First dip
« Reply #6 on: 14 Oct 2015, 04:01 pm »
Hello, Jin.
AC is a sprawling metropolis with vast knowledge to be gleaned from its various sections. I'm after the final piece in my audio jigsaw though, so just one question will suffice. Then I'll try to ride off contentedly into the sunset lest upgraditis hits me again. :o
"Jia you", I know that. :wink:
Xie xie!
Jin
mresseguie
Re: First dip
« Reply #7 on: 14 Oct 2015, 04:23 pm »
Bu ke qi!
I thought it likely that you might know the language, but I didn't wish to put you in a corner. I'm in Taoyuan City, Taiwan right until March 2016.
Michael
Guy 13
Re: First dip
« Reply #8 on: 14 Oct 2015, 04:46 pm »
Welcome conrad-Jin,
you have chosen the right forum,
AudioCircle is the (Only) place to be member.
Lots of helping members here with good knowledge.  :thumb:
Guy 13
SSM
Re: First dip
« Reply #9 on: 14 Oct 2015, 05:43 pm »
Hehe... Michael and Guy13...
I think our next collision will be in a particular section of AC... if you can get the clue from my avatar. :wink:
Jin
Phil A
Re: First dip
« Reply #10 on: 14 Oct 2015, 07:34 pm »
Welcome to AC!
Re: First dip
« Reply #11 on: 14 Oct 2015, 09:24 pm »
Jin
Welcome Jin. Your avatar is a GM70 amp?
Re: First dip
« Reply #12 on: 15 Oct 2015, 12:34 am »
Greetings & Welcome to AC Jin.  :thumb:
SSM
Re: First dip
« Reply #13 on: 24 Nov 2015, 07:57 pm »
Thanks guys. Sorry for the delayed response, I didn't come back to this section as I missed the notification alert.
FR-Man, that is a KT88 single-ended amp built by Dennis Had. :D
I have a query regarding my AC id name. Is it possible to have it changed?
Regards
Re: First dip
« Reply #14 on: 24 Nov 2015, 08:07 pm »
Regards
Check out this recent post from JohnR.
http://www.audiocircle.com/index.php?topic=138706.0
SSM
Re: First dip
« Reply #15 on: 6 Dec 2015, 08:23 pm »
Thanks Arthur. :)
SSM (formerly known as conrad-Jin)
