DVD From Australia on How To Build Tube Amps
0 Members and 1 Guest are viewing this topic. Read 1335 times.
taipan1013
« on: 11 Oct 2015, 07:28 pm »
When looking for resources to build my own tube amplifier I came across the following DVD set from Australia that instructs you how to build a tube amplifier.
http://www.ebay.com.au/itm/P2-DVD-program-BUILD-your-own-hi-fi-VALVE-TUBE-amplifier-construction-guide-300B-/251752794542
Has anyone used this video? Is it a good video to learn how to build a tube amp for a beginner?
Thanks for your help.
Greg
TubeNirvana
    • Tube Nirvana
Re: DVD From Australia on How To Build Tube Amps
« Reply #1 on: 23 Oct 2015, 01:51 am »
that seems to be a lot of $ for a DVD. No doubt the producer/s spent a lot of hours on it.
I have always been of the opinion that a tube amp is not for the raw beginner. There are high voltages present, which can be fatal to some, and neatness in wiring, layout etc etc are all very important.
Also, good soldering is an ABSOLUTE must!, especially because of the high voltage and in some case high currents, ie filament supplies.
You did not state if you have built electronic kits before?
You would probably be better off to buy a good quality kit for a tube amp, such as the Dyanco ST70 clone from Tubes4HiFi, or some of the kits from Parks Audio as some examples, do a search, as they all come with excellent step by step instructions.
As I mentioned above, to build an amp say from a diagram that you found, you really need to have some basic understanding of electronics and tube circuitry and be fairly handy with the soldering iron.
« Reply #2 on: 23 Oct 2015, 05:23 am »
Solder circuits are not easy or funny.
Tube amps must use hard wiring and
lead free solder, not stranded wire.
Just happen that soldering hard wire is
difficult, not easy as stranded wire and
lead free solder broke easily sometimes.
« Last Edit: 23 Oct 2015, 07:11 am by FullRangeMan »
