BDP-3?
0 Members and 1 Guest are viewing this topic. Read 3307 times.
Marius
BDP-3?
« on: 8 Oct 2015, 06:56 am »
Hi James, Chris,
Please tell us a bit of your plans please?
to be found in the bit about the Nas Share
https://dl.dropboxusercontent.com/u/86196657/Videos/BOSS/BOSS%20Intro.mov
cheers,
Marius
unincognito
    • bryston.com
Re: BDP-3?
« Reply #1 on: 8 Oct 2015, 11:59 am »
Hi James, Chris,
cheers,
Marius
Your going to be waiting a long time, scroll further down and there is mention of a BDP-4 as well.  We have a bunch of BDP-1's and BDP-2's on a network, anyone who has multiple of the same unit and use avahi/bonjour can verify this; avahi/bonjour will increase the value of the final character in the name (assuming it's a number) so that it can broadcast a unique id.  Just to clarify what I'm saying, these units listed are BDP-1 or 2's, but because we have 4 units on the same network they have had the vue increased to show BDP-3 and BDP-4.
Cheers
Chris
Marius
Re: BDP-3?
« Reply #2 on: 8 Oct 2015, 12:09 pm »
Too bad, was getting my hopes up.
Thanks.,
Marius
Cheers
Chris
unincognito
    • bryston.com
Re: BDP-3?
« Reply #3 on: 8 Oct 2015, 01:07 pm »
Thanks.,
Marius
Sorry, My bad
R. Daneel
Re: BDP-3?
« Reply #4 on: 10 Oct 2015, 10:56 am »
Hi!
But wasn't BDP-2 built to be expandable?
I mean, it's rear panel is attached to the chassis by screws instead of being a piece of the bottom panel bent upwards. This tells me the mechanical design of the device is such that it can accomodate different connector configurations by replacing the internal boards and the rear panel.
In addition, the machine has a removable cover on it's rear left (looking at the machine from behind). Is this to accomodate additional USB ports?
Cheers!
Antun
unincognito
    • bryston.com
Re: BDP-3?
« Reply #5 on: 10 Oct 2015, 11:52 am »
Hi!
Cheers!
Antun
People were so disappointed about not being able to upgrade there BDP-1's to BDP-2's that the revision changes (somewhere in the 200's I think) I changed the BDP-2 chassis to a two piece so that when we inevitably released the three customers could upgrade the system board.  When we do release the BDP-3, customer can buy the system board, rear metal panel and power cable.  Customers who have the older chassis will need to buy the additional metal work.  The power supply, audio device, dress panel, front panel controls remain unchanged.
Just to be clear BDP-1's not upgrade-able,
BDP-2's upgrade to BDP-3 system board is likely possible
« Last Edit: 16 Oct 2015, 03:05 pm by unincognito »
R. Daneel
Re: BDP-3?
« Reply #6 on: 10 Oct 2015, 01:31 pm »
Hi Chris!
This is excellent news! Thank you!
Cheers!
Antun
Norton
Re: BDP-3?
« Reply #7 on: 15 Oct 2015, 05:58 pm »
The more interesting question is what's missing from a BDP2 that might justify a BDP3?  It's a pretty comprehensive tool already.  I guess the software ability and processing power for user selectable filters, on the fly PCM upsampling and quad DSD transcoding (as per HQPlayer) would be useful.  Maybe a SD card transport too?  I2s interface?  Audiophile USB ports with switchable power?  More extensive direct power supply - direct feed to power SSD for example ?
Servingthemusic.com
Re: BDP-3?
« Reply #8 on: 15 Oct 2015, 09:07 pm »
Well said.
