0 Members and 1 Guest are viewing this topic. Read 6386 times.
I am trying to understand the important aspects of matching preamps to power amps, especially passive preamps. I have a few questions but I will start with this one:What characteristics of the preamp and power amp are the most important to insure best performance?Mike
You're not specific enough tubes,solid state,hybrids,it's not matching, most rather drive dynamics,passive preamps dont have the edge active preamps have...
IMO it would be the right impedance.According the old rule thumb the preamp should have output impedance 10x more than the power amp.My 2 cents.
The useful Decware site always help in these moments:http://www.decware.com/paper55.htm
FRM is top notch on this! ,but i think he's trying to tease you..
Quite possibly but the page he directed me to helped me understand part of the picture. Now to dig deeper. Why did I sleep through my physics classes 40 years ago?? Mike
Actually,I dont agree with the page he directed you,because it talks about sensitivities and clipping,preamplifier synergy (dynamics) is not about voltage levels but impendaces values these enhance dynamics...a source must have a low z out and a pwramps high z in...
It's a little strange that the Dodd is noisy compared to the NAD's preamp section (though the NAD's preamp is likely pretty quiet as it is class A). To be sure, you removed the pre-out / main-in links and connected the Dodd to the main-in input, correct?
If that's the case, and it's still noisy, I'd look at the tube. The Dodd is known for being super quiet. It is very doubtful you have an impedance issue. That's the main point of a buffer. It provides a nice, low, output impedance to the amp.
George. I disagree. Impedance isn't the only factor at play. Voltage and sensitivity are the other half of the equation....just as Decware explains.
Example: Pre= 100K ohms, Power=10K ohms.
This must be a typo.In a typical solid state system:Pre-amp output impedance 100 to 200 Ohms.Amplifier input impedance 10,000 to 100,000 Ohms.Compatibility might be a better word choice, rather than 'matching'.
You are right I invert the values.Sorry the fail.
...The tube I am using in the Dodd is a Reflektor 6H30-DP (toggle switch set at 6V). Should I get a new one of these tubes or would a different tube work better? ....
