OSX Networking Questions
0 Members and 1 Guest are viewing this topic. Read 1751 times.
Doublej
« on: 4 Oct 2015, 10:25 pm »
I have a 2008 imac running El Capitan. The wireless card has heat related issues so I am using a cheap router as a wireless bridge connected through the Ethernet port of the imac. Two questions related to this.
1. How do I disable the automatic startup of the wireless connection? Even though I have chosen ethernet as #1 in the service order the wifi connection still starts up.
2. In order to get the ethernet connection to connect every time I start the machine I need to click > System Preferences > Network > Ethernet > Assist me > Assistant  > Continue > I use a cable modem to activate the connection. How can I get it to automatically connect upon start up?
JohnR
Re: OSX Networking Questions
« Reply #1 on: 5 Oct 2015, 08:33 am »
Hi, I haven't installed El Capitan but on your question 1, I'd suggest just turning off the Wifi (System Preferences -> Network -> Wi-Fi). That might help with question 2  as well - ?
Doublej
« Reply #2 on: 9 Oct 2015, 11:57 pm »
No joy. I turned off the wifi as you have stated but it seems to turn itself back on after a few reboots.
What odd about the wired connection is that is connected according to system preferences and shows an IP address but to something in a browser I need to click on Assist me and then click on I connect using a cable modem. Once I do this it asks me to reenter the admin password on the imac and then changes the ipaddress to a different one and connects.
GentleBender
« Reply #3 on: 10 Oct 2015, 01:34 pm »
Have you ever done a "clean" install of the OS? If you've been upgrading the OS since the beginning, you may have some software related issues. Not that starting from scratch is fun, but I find that I rarely have the problems some people have after upgrading. Let me know if you are interested.
avta
« Reply #4 on: 10 Oct 2015, 02:10 pm »
Have you tried deleting the WiFi service in Network? ( System Preferences> Network> select WiFi> delete using minus sign )
Doublej
« Reply #5 on: 18 Oct 2015, 01:44 pm »
Yes. The imac seems 'smart' enough to know it's still there though and sometimes reactivate the wireless connection.
I am definitely interested in understanding how to do a clean install of the OS.
cody69
« Reply #6 on: 18 Oct 2015, 02:13 pm »
I have a 2010 iMac running El Capitan and recently re-configured the network to use an ethernet cable connected to the back of an airport extreme router instead of running on a wireless connection. As mentioned above, I went to System Preferences, Network, and turned off Wi-Fi using the list of network connections on the left-hand side. I re-booted the system and made sure it came back up with only the Ethernet connection showing Green and Connected.
Good luck
GentleBender
« Reply #7 on: 19 Oct 2015, 01:25 pm »
First make sure all important stuff is backed up using Time Machine or whatever else you may be using! Here is how I do a clean install. https://support.apple.com/en-us/HT201372 Here is another option http://mashable.com/2015/10/01/clean-install-os-x-el-capitan/#G3ZATnAnREqr so you can choose the one you are most comfortable with. Follow these directions exactly and you can find if it is just software problems plaguing you.
What makes you think it is heat related problem with the wifi card?
Doublej
« Reply #8 on: 1 Nov 2015, 02:20 pm »
I am running Mac Fan Control on the machine and I notice when the temperature is low, 40 degrees Celsius, wifi seems to work fine. As the temperature climbs towards 50 degrees performance degrades and then wifi cuts in and out.
I haven't done the clean install yet. I don't use the machine for much except for music streaming so I need to go through it and make sure I have everything I want backed up.
