Thinking of upgrading my system
0 Members and 1 Guest are viewing this topic. Read 925 times.
ctviggen
« on: 3 Oct 2015, 07:55 pm »
I have Grado SR225s and use a D/A converter, AUDIOQUEST - DRAGONFLY V1.2 USB DAC:
http://www.amazon.com/AUDIOQUEST-DRAGONFLY-V1-2-USB-DAC/dp/B00H00VLZQ/ref=sr_1_1?s=electronics&ie=UTF8&qid=1443901539&sr=1-1&keywords=audioquest+dragonfly+v1.2
I use this system to listen to FLAC files at work.  I listen all day long.  I listen to a very wide range of music, although not much that's "heavy".
I am thinking of spending $500 to upgrade my system.  I was thinking of these headphones (Sennheiser HD 650 Open Back Professional Headphone):
http://www.amazon.com/dp/B00018MSNI/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=15LWHGA04FA5N&coliid=I1L6X2SATW057A
Or maybe a tube amp (Valhalla 2):
http://schiit.com/products/valhalla-2
I'm concerned about tube amps, though.  I've tried this one, which failed very quickly (a month?):
http://www.amazon.com/gp/product/B00A2QM5O6?psc=1&redirect=true&ref_=oh_aui_search_detailpage
I tried four different sets of tubes on that one.
I tried this one, which lasted longer (maybe 6 months):
http://www.amazon.com/gp/product/B00A2QKTLW?psc=1&redirect=true&ref_=oh_aui_search_detailpage
On this one, I had three or four tubes.
I'm concerned I'll buy yet another tube amp that will fail quickly.
Should I consider a better set of headphones, tube amp, analog amp, or something else?
Guy 13
Re: Thinking of upgrading my system
« Reply #1 on: 3 Oct 2015, 08:30 pm »
Hi ctviggen,
I have a pair of HD650 driven by a Bottlehead Crack.
I've used it for more than a year and no problem with the tubes and or electronics.
The headphone amplifier is a kit,
but at Bottlehead they have someone that can put it together for you.
It's not small like the ones you mentionned, but that a plus,
more room for the components to have air to cool down.
Guy 13
