Does the BDP need to be a server?
0 Members and 1 Guest are viewing this topic. Read 1633 times.
Marius
« on: 3 Oct 2015, 04:03 pm »
HI Chris,
While I've been playing  more and more music from my NAS, I've been wondering if the BDP really needs to be a server, instead of only being a dedicated digital player. Imagining the BDP without attached local USB drives, and only connecting to the (ether) net.
What software would you need for that? Could it be a dedicated Plex version for Unix for example, and would it fit on a BDP?
Just as you have made a bdp1usb recently, stripping out its sound card, you could make an ever thinner client, optimized for playing streams and elsewhere stored files. And by doing so, relieve the BDP from the MPD software and BDP-version of it.
I feel the BDP is starting to be torn apart: a very potent dedicated computer hardware wise,  a tough unix machine on the other hand, somewhat behind in the user interface and functionality. Prone to more and more issues of non-responsiveness and needing to reboot ever so often. we'll sit tight, since we love the machine the way it plays music. Still, some endurance is needed...
I know Bryston (you) is working its socks off, developing the software. But compared to several other interfaces, it is starting to be a bit 'dated'.
Hope you will consider this thinner client minus MPD, and love to hear your thoughts on it.
Cheers, Marius
unincognito
    • bryston.com
Re: Does the BDP need to be a server?
« Reply #1 on: 3 Oct 2015, 07:58 pm »
HI Chris,
Cheers, Marius
It already has that capability, you can turn off MPD and use it purely as a renderer.  Current choices include DLNA (same thing plex uses), squeezebox and the airplay emulator.  Let me point out though, one if the reasons the BDP does sound so good in the first place is MPD.
Marius
« Reply #2 on: 3 Oct 2015, 08:37 pm »
Hi Chris
Sure I've deselected mpd in settings to try . But how to read the files and play those , when stored on the Nas? I can't see them in MM. I can play it over shairplay from within plex, but missing the 24bt resolution .
Marius
tdb4rdd
« Reply #3 on: 4 Oct 2015, 12:52 pm »
Can someone please explain the setup to connect BDP to NAS?
mav52
« Reply #4 on: 4 Oct 2015, 01:11 pm »
I found this helpful
https://www.youtube.com/watch?v=9M3Z8MggLJo
R. Daneel
« Reply #5 on: 7 Oct 2015, 02:16 pm »
Hi Chris!
Can you elaborate on that? What does MPD have and other applications do not?
