AR- LST High Freq's not working. Any LST crossover experts around?
0 Members and 1 Guest are viewing this topic. Read 5032 times.
bhans
I hooked up the old AR- LST speakers and notice the high frequency drivers are not working. Pulled the back panel with the crossover and started looking around. There is a 6uf cap that goes to the high freq. I bypassed that and still no luck. Any recommendations how I should trace the problem down?
S Clark
Disconnect a wire from the speaker and run an ohm meter across the speaker leads to see if the voice coils on the tweeters are still continuous.  If they are, I'd replace all the capacitors with upgrades.  They are probably way out of spec by now.
bhans
Thanks for the suggestion S Clark. I have taken the speaker wires from the amp and put them on one of the tweeters and they all work when connected directly to the tweeters. I would think by bypassing the 6uf 50v cap I would have sound. Granted the caps are out of spec but I don't think this is where my problem is. I just don't know where to go from here.
S Clark
If the tweeters play when connected to the amp, then replace
all
the caps.  These speakers are collectable and worth spending a few bucks on, and these were likely cheap caps anyway. Upgrading caps would be $50-100 well spent   Check the solder connections to the coils(chokes).  It might be a good idea to re-solder them anyway.  If the drivers play, the problem has to be in the crossover or the speaker connectors.
bhans
Thanks. While looking for new caps I do not see 6uf 50 volt. I do see 6uf 400 volt. Would these be compatible? Does voltage matter as long as they are a higher value?
Wayner
Don't the LSTs have a tweeter level control? If so, that is where your problem is.
G Georgopoulos
volts doesnt matter as long as it is same or higher
Yes higher volts means it can work even in higher power systems,compatible yes (value the same)
cheers  :green:
bhans
There is not a dedicated high freq adjustment. It has a selector the attenuates Both high freq and mid freq.
S Clark
After looking at that mess of a crossover, wow... I don't know what I'd do.  Probably take it to one the pros and have them redesign the crossover, or bypass stuff until it plays and then sell it.
bhans
S Clark, I have to figure this out. These are really lovely sounding speakers when they work properly. Twenty plus years of sitting unconnected or used did something to the speakers and I got to solve this issue. My kids can sell them after I'm dead. They wont know anything about them and probably sell them for $20.00 or so. Anyways, here's the rest of the description I pasted below.
S Clark
Ok, then you need to find the break.  Is the speaker dead regardless of which position the autotransformer is set to?  Can you measure continuity from the positive binding post through to where it connects to the 6uF cap? If so, move the 6 position switch to see of all the coils in the transformer are passing current. If the short is in that transformer, then I've got to hand this off to someone above my pay grade.
