Google Chromecast Audio- Output?
0 Members and 1 Guest are viewing this topic. Read 1461 times.
kbuzz3
« on: 30 Sep 2015, 06:57 pm »
Has anyone run into any info as to the output specs?  Wondering if its limited ala Sonos or could possible do higher rates. In other words any idea what file formats it will support. -Is output set at CD-quality (16-bit/44.1kHz) or will it support  "hi-res" audio up to 24-bit/192kHz?
Brad
Re: Google Chromecast Audio- Output?
« Reply #1 on: 30 Sep 2015, 07:50 pm »
Looks like it'll go up to 24/96
https://support.google.com/chromecast/answer/6279377?hl=en-GB
They don't give much detail though  :?
kbuzz3
« Reply #2 on: 30 Sep 2015, 08:20 pm »
figured id add one more question: does it support and play local files (i.e. ripped cds) or just streaming services?
mr_bill
« Reply #3 on: 30 Sep 2015, 10:04 pm »
Anything you can cast from your phone.
jpm
« Reply #4 on: 30 Sep 2015, 10:39 pm »
Most likely you can play via anything that will run Google Chrome.
Good write up, as usual, by John Darko:
http://www.digitalaudioreview.net/2015/09/google-chromecast-audio-set-to-disrupt-audio-streamers/
