Allnic D5000 DHT DAC $7900. Excellent condition
0 Members and 1 Guest are viewing this topic. Read 790 times.
ketcham
« on: 22 Sep 2015, 06:49 pm »
For sale:  Almost new condition D5000.  All updated components, extra set of tubes.  Under 200 hrs.
Reason for selling: I have an all Allnic System and I feel the added benefit the D5000 is muted in my system.
See the review below.  (Disclaimer:  I wrote it.)
I know all aspects of this dac.  Feel free to ask questions.
Inputs:
2 Coax
1 Toslink
1 AES/EBU
1 USB
Output:
Balanced XLR
RCA
Analog Specifications:
1) Output RMS voltage: 2.5V
2) Output impedance: 150 ohms constant
3) Frequency range: 20 Hz-20 KHz flat
4) THD: less than 0.1%
5) Tubes: DHT: 3A5 X4; Tube-based internal power supply: 7233X1, 5654X1
6) Dimension: 430mm, 290mm, 150mm (W, D, H: 17", 7.4", 6")
7) Weight: 9.2 Kg
8) Power consumption: 23W /230/50Hz Or 23W/120V/60Hz for North America.
Digital Specifications:
1) Toslink Sampling limit 96 kHz (Note: In case of TOSLINK, some devices will work correctly with D5000 at any rate. This depends on the signal quality of the transport.)
2) AES/EBU and Coax sampling limit 192 kHz (if the source is SPDIF standard compliant). Higher sampling rates have been demonstrated with some source components.
3) USB Sampling limit 384 kHz, DSD128
4) USB Input Custom USB Audio Interface design with Cypress FX2/FPGA
5) DAC Dual Mono/Mono ES9018K-2M Reference Audio DAC
6) Word Clock: Clock Reference Output, Clock Reference Input
7) DSD Conversion FPGA Based DSD Converter: PCM to input DSD128
8) Upsampling FPGA Based Upsampler: Up to 384 KHz
9) Mac OSX 10.6, Linux OS with UAC2, Windows OS (Thesycon Driver)
List Price: $11,900 USD.
http://www.computeraudiophile.com/f6-dac-digital-analog-conversion/new-direct-heated-triode-tube-digital-analogue-converter-allnic-audio-labs-21318/
ketcham
Re: Allnic D5000 DHT DAC $7900. Excellent condition
« Reply #1 on: 22 Oct 2015, 08:56 pm »
Bump.  Offers will be considered.  A ton of excellent dacs out there.  Depending on your need I can suggest others to consider auditioning.
