No love for the Pioneer N-30 or N-50?
0 Members and 1 Guest are viewing this topic. Read 1740 times.
STEREOmole
« on: 21 Sep 2015, 05:55 am »
Am I the only person on the face of the earth that uses one of these (N-30/N-50)??  It seems to be a no-brainer for price and performance...and I've been really happy w/ the sound and performance.
maxboy00
Re: No love for the Pioneer N-30 or N-50?
« Reply #1 on: 21 Sep 2015, 11:10 am »
Which one do you have?
What DAC are you using?
Been looking at streamers for a while but,  I'm still undecided on which type of player format to get NAS based or an on board hard drive?
What is that you like about this player in particular?
STEREOmole
« Reply #2 on: 21 Sep 2015, 12:00 pm »
I'm currently using a N-30 with a N-50 on the way (for a second system in my living room).
I've been using a DIY Monica NOS DAC w/ the N-30.  The onboard DAC sounds OK, however.
The issue I have with on board hard drives, is that the new mechanical hard drives have terrible reliability.  How do you back-up a proprietary on-board HD streamer?  The biggest PITA is the amount of time that it takes to rip a collection to CD, and to have it tagged properly and include the artwork.  Backups are a necessity IMO.
I like the fact that there really isn't a lot for me to dislike.
Pros:
It plays any format that I throw at it, in full resolution, with the exception of DSD (the new models playback DSD files).
It sounds great!  It's easily as good, or better sounding than playback from a CD player to my DAC.  I believe it reclocks the stream.
It has a color display with track info and album cover art
It can be found on eBay for a budget price (easily under $400 new in box)
I can stream over my network from my music server PC (running Minimserver), my cellphone, my laptop, etc.
It has a cellphone app that allows for gapless playback of FLAC files (I haven't confirmed that the gapless playback works...I use BubblePNP w/ Android)
It's non-proprietary...it supports a multitude of formats and I don't need a special server (just one that's DLNA compliant) to make it work.
Cons:
I wish the display showed the album art larger and the song title smaller.
It isn't easy to navigate the menus with the remote or the buttons on the unit itself.
The Pioneer Control App kind of sucks (doesn't display album art on your phone, is difficult to navigate.  This can be bypassed by using BubblePNP or UpNp Android apps which work great w/ the N-30)
-Hope that helps.
maxboy00
« Reply #3 on: 22 Sep 2015, 12:08 am »
Much thanks for your reply!
I assume that you are using a NAS based system, it seems that is probably the better approach to using a network player  since it adds overall flexibility.
As your title suggests, I have not looked much at Pioneer, but it deserves a hard look.
STEREOmole
« Reply #4 on: 22 Sep 2015, 07:20 am »
No, I use a PC running Ubuntu and MinimServer (http://minimserver.com/).  Maybe once I have all of my discs ripped, and my music is all tagged properly and organized, I'll look at moving the drive over to a NAS.  For right now, the PC is more flexible, as I have it set up to rip a disc to FLAC as soon as it's inserted into the drive.  It'll tag most CDs properly, and for the most part is an automated process.
