0 Members and 1 Guest are viewing this topic. Read 11756 times.
Thanks for the ideas.Hugh, is the KR significantly better than the EML? There is a great price difference.Mijknarf, I have read some good things about the Shuguang and from your experience they seem dependable.
I found some NOS RCA 2A3 black plates offered by reputable dealers. Are they comparable in sound quality to the new production tubes like the JJs? With small signal tubes I would have no hesitation about NOS tubes but I have no experience with NOS power tubes like 2A3s.
Thanks for the good suggestions. I get confused with all the different Chinese offerings: Shuguang, Sophia, TJ, Psvane and I am concerned about reliability. However, I have used some Shuguang 6SN7 and also Psvane CV 181 T tubes in another pre/amp combination without any issues.
Hi Boris,If you're concerned about reliability, get a used (that tests strong) or NOS pair of US-made 2A3 tubes. They are the original 2A3! I agree with Hugh - you can't go wrong with RCA (I like black plates best, but all versions sound great). My favorites are the Sylvania 2A3 with coil-spring tops rather than a filament suspension (left tube is spring / right tube is suspension) ... Also Ken-Rad with smoked glass sound great...Many "off brands" were made by RCA & re-branded. You can tell by looking at the plate & filament structure. They are often priced "right".The closest sounding to original USA-made tubes is the Russian-made Electro Harmonix Gold grid 2A3... sounds pretty good & is stable...My $0.02,Pete
I also have EML solids, sound great no problems after 3 months. Pete, message me a good source for Sylvania if you know of one... Hugh, just send me RCA tubes
